ARF Repair
Old 01-12-2007, 06:24 AM
drksky1056
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ARF Repair
Well...more like a preventative fix.
I've got a Giant Super Sportster that had a couple of rough landings when I was first flying and I've noticed that the landing gear on one side is getting a bit wobbly. It looks like the impact of the rough landings has caused the in the wing block for the gear to hog out a little bit. My concern is that as time goes on, it's only going to get worse and the gear is eventually going to fold on that side.
Any ideas to stop or reverse the process without having to dismantle the wing?
drksky1056 is offline
Old 01-12-2007, 07:33 AM
Roby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ARF Repair
If I understand the problem correctly,it seems that
the hole for the gear leg has gotten oversized.
If this is the case then get a proper sized dowel ,plug the
hole and then redrill it to the correct size.
Regards,
Roby
Roby is offline
Old 01-12-2007, 07:47 AM
AVGJohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep
AVGJohn is offline
Old 01-12-2007, 10:01 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OR...
Mix up some epoxy (5-minute or 30-minute, but let it get a little thick so it won't run too quickly)
Stuff it into the hole, let it harden and re-drill
MinnFlyer is offline
Old 01-12-2007, 12:26 PM
Charlie P.
Charlie P.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also wipe paste wax on the strut and then epoxy it in place. Put it on thick and buff it up, but not enough to remove it all. The wax will allow it to be removed if necessary later and it will be a 99-44/100% perfect fit.
Charlie P. is offline
Old 01-13-2007, 06:27 AM
drksky1056
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
D'oh! Can't believe I didn't think about the dowel thing. Yeah, that's exactly what's happened. Stress on the gear during the hard landings has caused the holes to enlarge.
I wonder if the epoxy wouldn't work better though. It didn't seem like these landings were all that hard which may indicate that the gear block isn't really hard (which wouldn't surprise me on an ARF). The epoxy might help keep it from happening agian.
Thanks a bunch.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
