New Monokote Technique
Reply
Old 07-07-2009, 11:02 PM
  #76
catracer343
catracer343's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Monokote Technique
Thanks Lomcevek! I owe it to you! I did a 3D American flag on the topside of the wings with Ultrakote...12 hours worth of fiddling with my trim iron, but it all came together in the end.
ID:	1231783   Click image for larger version
catracer343 is offline
Old 07-11-2009, 01:19 PM
  #77
MrFahrenheit
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brilliant! Thanks for the great info.
@catracer343: Wow! Really nice work there... some of the best I've seen.
MrFahrenheit is offline
Old 08-25-2009, 10:59 AM
  #78
deckerv
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A small pic of the first try at this technique for me It's the University of Rochester Yellow Jacket bee on my Florio Flyer Suntwagon
deckerv is offline
Old 12-23-2009, 01:45 PM
  #79
Bob Paris
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hay Good Buddy,
That was an awesome tip and I've been using Super Monocote since it was known as just "Monocote." I can't wait to try it out on the model I'm building now...!
Soft Landings Always,
Bobby of Maui
Bob Paris is offline
Old 05-01-2010, 10:27 PM
  #80
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
excellent video....thanks!!
tailskid is online now
Old 01-21-2011, 06:02 PM
  #81
emilsanto
emilsanto's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow you should have done a video on how to do that
great job
emilsanto is offline
Old 02-11-2011, 08:14 AM
  #82
ScaleRCpilot
ScaleRCpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very well done! This procedure would work well for making insignias for our Scale Warbirds. Also noseart for say a B-25 or B-17 Bomber.
Thanks much!
SR/CP AKA: Rocknranchman (youtube)
ScaleRCpilot is offline
Old 04-04-2011, 04:55 PM
  #83
albsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My curiosity was peaked after reading this forum and seeing the video that used a complex pattern template that was free-hand cut on glass. I had read a couple of other forums/posts about cutting patterns and sealing monokote and ultra-cote. Why can't you do it on a standard cutting mat?
After cutting a test piece of monokote on my cutting mat last night, I cut it into 4 squares, peeled the backing off, and used 4 liquid mediums to cling it to my cutting mat. I figured I'd do a simple template cut on each and try the Glad “Press n Seal” method to lift and transfer them to a clear piece of monokote. Water, alcohol, Windex, and Arm & Hammer Multi-surface “green” cleaner all got the test squares to adhere to my cutting mat. Water was a little difficult.
Using water to hold monokote down didn't last through this morning on the mat. The best cling was standard drugstore alcohol, and the two cleaners held the same. Cutting the patterns was fine with construction paper. I tried 20 lb bond copying paper, but it tore too much, but just a little less than regular paper. They all lifted fine with Press n Seal and transferred to a test piece of monokote. I used my covering iron to seal them down and a little Top Flite trim solvent to get the edges. It's now 6 hours later and they are all holding fine in my garage which is 94 degs right now.
albsurfer is offline
Old 04-05-2011, 11:15 AM
  #84
picard1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For me cutting on glass leaves a crisper line than using a mat, but mostly there is less drag on the tip of the blade. Just a feel thing...
picard1 is offline
Old 04-05-2011, 11:31 AM
  #85
albsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I haven't done a full monokoting since I started this hobby in 2006, just patching, no designs or trim. I figured I'd see if the mat would work, and if it really mattered if you used Windex or not. I didn't do anything complex, and I'd bet the mat could easily be a problem on a complex design with small pieces or intricate lines. I just used a 2x3" killer whale design for the test. I did have a problem doing the eyes and I wasn't sure if it was the mat or the construction paper causing the problem. The blade seemed to grab a little during parts of the circle and the eye oval. The rest seemed to have good edges, but I did have to press down a little during the cutting to get through the monokote.
Old 04-05-2011, 02:02 PM
  #86
mirwin
mirwin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
albsurfer,
A couple of tips for you:
- Change the blade as soon as you feel that it isn't cutting smoothly. On a complex job, I'll go through 4 - 5 blades.
- Second: After applying the monokote to the base monokote and after you've squeegied all the liquid out, let it sit for at least 12 hours before sealing the edges with the Trim Solvent.
- ordinarily, you don't need to use any heat; it'll stay there till the cows come home. I have an 8 year old Super Skybolt and the design is as tight on all edges as it was the day I laid it down.
Mike
ID:	1589772   Click image for larger version
mirwin is offline
Old 04-05-2011, 04:01 PM
  #87
albsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
mirwin,
thanks for the advice. I'll try it out on my plane. I'm going to do the base coat tomorrow on a good share of it, then cut big trim pieces and put them down. I used the trim solvent on a couple of other planes I purchased to hold down the stripes when they tried to peel off after a few flights. It works good.
I have a wing left over from a Phoenix Models Tucano 40 that I've been stripping down for wood. I noticed that they used a woodpecker tool to make holes in the base covering and wood everywhere they laid down trim pieces like you have on yours so it would vent through and not create as many bubbles. I have read that this helps prevent bubbles when using heat, but have also read that it's unnecessary when heat is not applied. I'll try your method out because I don't really want to heat up the monokote twice.
Thanks to everyone for their comments on this subject.
Thanks to lomcevek1 for his video. I'll post a picture of my PRIMO after I'm done covering it. It won't have a nice design as yours, though. I do like the Swany Primo finish on his site, too.
Old 11-20-2011, 05:33 PM
  #88
padlock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ive tried several brands of window cleaner and pure ammonia. None of these products activate monokote glue. I do not know where this got started but it does not work.
sbdwag
padlock is offline
Old 11-20-2011, 06:29 PM
  #89
albsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: albsurfer
mirwin,
Sorry guys, I forgot to post a picture after I finished.
The windex only helped hold the monocote stay down on fairly flat areas. The monokote peeled up from the aileron chamfers when it dried. I used the trim solvent to hold a lot of it down, but I still had to use an iron on the trim pieces to keep it down. The blue gave me the most trouble. It could be that this monokote was pretty old, since i got it from someone else. I've talked to a few guys at my field since then and was told that Monokote on monokote is pretty difficult to do without high heat on it after sealing the edges.
Here's a couple of pics. the top & bottom of the plane is different, but same colours.
Left is the top of the plane. Right is the bottom.
ID:	1689156   Click image for larger version
Old 11-21-2011, 03:52 AM
  #90
deckerv
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Florio Stuntwagonfinished with this technique
deckerv is offline
Old 11-21-2011, 01:28 PM
  #91
albsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
deckerv,
I like it. Looks great.
Old 11-21-2011, 02:53 PM
  #92
rye
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi deckerv
can you give me the detail on how you did yours with two colors thanks rye
rye is offline
Old 11-22-2011, 07:28 PM
  #93
deckerv
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!!! Pretty much did what the others did.. but for the yellow, I just cut the rough outline of the entire area. I put the yellow down first, then the blue on top of it. The metallic blue monokote has all the detail.
Can get closer pics if you'd like
deckerv is offline
Old 12-07-2011, 01:43 PM
  #94
skeeter_ca
skeeter_ca's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How do you use Trim Solvent. I had some pieces that would not stay down and bought some trim solvent. It didn't work worth a darn. I put it under the piece. Over the piece. In the crack. Held it down. Ironed it down. and if you used it to much it would make the color run. Nothing worked.
Also someone brought up that windex does not activate the glue. I've used windex to help lay down and position the Monokote trim sheets but i thought it was just to help keep it from sticking so you could position the piece then squegee out the windex and it sticks.
skeeter
skeeter_ca is offline
Old 12-07-2011, 04:43 PM
  #95
albsurfer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
skeeter ca,
yeah, the whole thing about windex activating the glue is BS. I dip a q-tip into the trim solvent, then swirl it against the inside of the bottle opening and make sure none is running out. I lightly swab it around the edges of the Monokote I want to stay down after that. I wipe the edge i just swiped with a paper towel to get the excess solvent off immediately. I experimented with a bit on a wing from a crashed plane after my first attempt didn't turn out well.
Sometimes it doesn't hold it all down correctly, so I have to use the trim iron on those areas, but make sure it's dry first.
If you have to iron Monokote on Monokote, TURN THE HEAT UP HIGH!!! A guy in another forum gave me that advice and it works. You just have to put up with a few minor bubbles. You can always take a needle and pop the small bubble and iron it down quickly.
Good luck.
Old 12-07-2011, 06:37 PM
  #96
tacx
tacx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I lay down my Monokote over Monokote with alcohol. Works for me.
tacx is offline
Old 01-15-2012, 08:17 PM
  #97
skeeter_ca
skeeter_ca's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw some vague mention of Ultracote. Has anyone used this method with Ultracote and if so what modifications to the method did you have to do?
skeeter
Old 01-15-2012, 08:41 PM
  #98
cublover
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice!!! learn something new everyday....
cublover is offline
Old 01-27-2012, 11:06 AM
  #99
lomcevek1
lomcevek1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It has been a while since I have flown but it is nice to see this thread is still alive and kicking. When I made that video I never anticipated this much interest so Thank you for watching and I am glad if it was able to help.
Plenty of gorgeous airplanes out there.
lomcevek1 is offline
Old 01-27-2012, 02:13 PM
  #100
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'd say that we should do what we can to keep the thread alive and have some subscribers show what they've been able to do with your video, to give other guys similar ideas.
Bob
N1EDM is offline
Reply
Display Modes
