Anyone have alternat thinner for Butyrate Dope?
My Feedback: (10)
FL
I ran out of thinner for Butyrate clear dope and was wondering if I could use Laquer thinner such as sold by Home Depot? I reduce the clear dope by 50% and use this to apply light fiberglas cloth. I apply a quick coat. the idea is hold the cloth down and not saturate. I then apply laminating epoxy resin and squeegie thye excess out. You will be amazed how much epoxy is removed. Gives a light finish ready for primer.
Please let me know about the thinning agent.
Thanks.
Crashlander
Thanks.
Crashlander
TX
RE: Anyone have alternat thinner for Butyrate Dope?
Acrylic Laquer Thinner from an auto paint supplier works well to thin Butyrate Dope. If available , use the high gloss (slow drying) type.
ORIGINAL: Herb Brown
I did this, just last week. It worked well.
My Feedback: (8)
ID
crashlander
I cover all my large aircraft with fabric and butyrate and use laquer thinner from Ace Hardware. Put about 10% in and mix then keep adding as needed if you put it in all at once it shocks the dope and is hard to mix.
Best Ron
Best Ron
ORIGINAL: rwfly
crashlander
Best Ron
crashlander
Best Ron
ORIGINAL: rwfly
crashlander
Best Ron
crashlander
Best Ron
ORIGINAL: Hircflyer
How about nitrate dope? Can you still use laquer thinner? We have a hard time getting dope thinner because its considered "HazMat" and shippig costs ate high.
ORIGINAL: rwfly
crashlander
Best Ron
crashlander
Best Ron
Automotive AcrylicLacquer thinner will work here, too.
Keep in mind not all acetones are equal. I recently covered a J3 with nitrate and thined with Lowes brand acetone, turned to cottage cheese pretty quick and there was no recovering from it. It was way too hot. Later I used Home Depot brand acetone, worked great. And you DO need to stir it a bit to get a good mix. Hadnt thought of Ace. Will try it next since thats the closest hardware store to me. I tried a laqure thinner and didnt have much luck with it, not as hot as Lowes acetone but hotter than the Home Depot acetone. It still turned a thick white goo.
The HD acetone worked great for applying koveral with stix-it. Thinned stix-it about 50/50, when dried, I used a small artist paint brush to just apply HD acetone on the perimeter and the koveral was stuck down with in seconds. Then came back later with the nitrate.
Edwin
Edwin
