Paint Match for Ultracote Cub yellow
Reply
Old 06-18-2009, 03:16 PM
rjp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Paint Match for Ultracote Cub yellow
I'm looking for spray paint that matches Ultracote Cub yellow. Any ideas?
rjp is offline
Old 06-18-2009, 03:25 PM
nedyob
My Feedback: (67)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Paint Match for Ultracote Cub yellow
Try Testors Brand spray paint.
NEDYOB
nedyob is offline
Old 06-18-2009, 05:00 PM
porthole200
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ultracote cub yellow spray paint from Hanger 9
porthole200 is offline
Old 06-18-2009, 10:09 PM
JCOKEEFE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take a sample of the Ultracote covering to a local automotive parts supply that mixes automotive paint in a
spray can and have them match the Ultracote color. I've been doing this for the last several years and you
end up with a great color match up. You will also need to ask them for a clear coat which will provide the
appropriate fuel proof protection.
JCOKEEFE is offline
Old 06-19-2009, 02:11 PM
Campy
Campy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can take a piece of covering and have a quart of latex mixed for an exact match for about $10. Latex will need to be clear coated if you are using a glow engine - gasoline engines, the paint fine as is
Campy is offline
Old 06-22-2009, 12:06 PM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had the same problem matching Ultrcote Bright Yellow. I started with the Ultracote spray paint it didn't even come close. I went with a bright yellow Krylon it looked closer to Cub Yellow. I would recomend the latex custom mix I think it will be the closest you will come.
FlyerInOKC is online now
Old 06-22-2009, 07:19 PM
rjp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the help. I tried Testors enamel spray paint #1214 (High gloss yellow). It matched perfectly! I plan on giving it a coat of lustercote clear to fuel proof it.
Rick
rjp is offline
Old 06-23-2009, 01:08 PM
GarySS
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please let us know of the clearcoat is compatible with the Testors paint.. Thanks!
GarySS is offline
Old 06-23-2009, 01:42 PM
TEBerg
TEBerg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just used LustreKote Flat Clear over my Skyraider that had Tamiya Paint in the can. It worked fine, but you have to to with two light coats of clear andDO NOTshoot theclearcoat heavy!
Two light coatswill "soften" the color paint for about 12 hours to a day, then set up just fine. A heavy clear coat will melt the color paint and you will get wrinkles/cracks.
I don't know ifTamiya sprayis the same paint as Testors spray, but I used some Testors brushed on paint with the same result.
Just test out the paint on a scrap first and see what happens.
For my clear canopy, I even used flat black Tamiya paint for the base coat of the frame because it grabbed the lexan great. Then used LustreKote paint for the color of the frame and fuel proofing. It worked great.
Good Luck
TEBerg is offline
Old 06-30-2009, 04:07 PM
rjp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys! I'll let you know how it turns out.
rjp is offline
Old 07-21-2009, 12:34 PM
SoCalSal
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nelson's hobby has the matching paint for this stuff http://www.nelsonhobby.com/paint.html
SoCalSal is offline
Contact Us Archive Advertising Cookie Policy
