Sheeting Foam Wings with ordinary brown paper.
Hi everybody,
I read some posts on the internet about people using ordinary brown paper and white glue or some kind of resin to sheeting foam wings. Did anyone here try this method of sheeting foam wings?
I'm designing my own DLG glider and I would like to know if it is a good and light method to sheet wings.
If someone has pictures or videos about the process, they are welcome!!!
Best Regards
Eduardo
Best Regards
Eduardo
RE: Sheeting Foam Wings with ordinary brown paper.
Somewhere around here I have a well written book, by an Englishman, that details his work in that area. He built some amazing gliders with foam and brown paper. Hope I can find it tomorrow. If so, I'll post the name and author Rich
Check these articles out:
http://www.charlesriverrc.org/articl...ersheeting.htm
http://findarticles.com/p/articles/m...8/ai_n8871174/
Yes I have ..about 15 years ago a friend and I built 5 planes all with foam fuse and wings and covered with brown paper...we had a couple of 40 size and a 60 size in the fleet and the sysem worked a treat...It turned out light and strong and all planes flew really well. after the finishing was done you would not know the difference to any other covering.
We used thinned white glue and just the ordinary rapping brown paper. Remember you can get different weights of paper.
A guy by the name of chris Gold in the UK has used this system on a lot of his models.....cheers
MB, CANADA
A friend of mine thaught me to use news paper with white glue. works good, but there is a grain to the paper and must be used with the grain in the right direction.
roltech
roltech
How do you tell which direction the grain is in the paper?
Jim
Jim
ORIGINAL: roltech
roltech
roltech
Tear it. The tear will continue in a relatively straight line along the grain but will not against the grain.
I was reading an old RCM the other day from my stash and some used very lighweight cardboard over foam with good success as well.
1 Post
By all means give it a try but I think you are going to run into serious wing warping problems because the shrinkage with brown paper is considerable.
I have built a number of 36 inch span 12th scale combat models with brown paper covering and the wing warps were easy to get out. When I went up to a high aspect ratio TA 152 at 48 inch span getting a true wing was next to impossible and I finished up glassing direct to blue foam and had success.
Assuming your DLG is in the region of 50 to 60 inch span and high aspect ratio then glass it rather than use brown paper.
ORIGINAL: edulago
Hi everybody,
Best Regards
Eduardo
Hi everybody,
Best Regards
Eduardo
They were60 sizeglow engine"Sticks" - were heavier than your balsa built ones but it flew OK, the advantage wasthat you could make a couple of fuses and wings. But the leading edge/trailing edge and aileronswere balsa on both wing, tailplane and fin.
Going for brown paper will just cause problems as you still need to re-inforce the wing, then coat it with your paper... I guess it all depends on the wingspan and the design of the plane......
Hi Everybody.
thanks for all comments... I will think more about using ordinary paper... If I decide to use, I will post the results here...
Best Regards
Best Regards
