RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Tips & Techniques (http://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   transparant wing covering (http://www.rcuniverse.com/forum/tips-techniques-180/11299907-transparant-wing-covering.html)
coralsea 11-16-2012 06:27 PM
any and all tips for a biginner
wickedpissa 11-17-2012 06:05 PM
RE: transparant wing covering
Have you covered before? If yes what<div>
</div><div>If no skip the transparent and go solid. Covering takes practice the transparent will highlight the mistakes not seen in solid.  Minnflyer made a great how-to on covering </div><div>
</div><div>
</div><div>http://www.rcuniverse.com/forum/m_11036716/tm.htm</div>
GarySS 11-18-2012 05:30 AM
Transparent coverings are cool and I like them, but they can cause severe disorientation up In the air and out at a distance. So be careful. Maybe you should observe some actual examples that are flying and then decide if transparent covering is for your project.:)
JPMacG 11-18-2012 04:51 PM
I agree with GarySS. I covered a Burrito with transparent red. From the ground it looked like a tight formation of flying sticks.
After losing orientation several times, one resulting in a minor crash, I recovered the bottom of the wings with solid.
John 38 11-19-2012 12:36 AM
I have used red transparent a lot and never had any problems re orientation - but this is on models minimum 72" span.
Red is one of the best for standing out and showing its colour way up particularly against a blue sky
What is model you are building?
john
