RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Tips & Techniques (http://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Help: I need to remove CA from nylon tailwheel bearing (http://www.rcuniverse.com/forum/tips-techniques-180/11300292-help-i-need-remove-ca-nylon-tailwheel-bearing.html)
bugdr 11-17-2012 06:54 AM
Is there anyway to remove CA from a nylon tailwheel bearing? I was installing the rudder and tailwheel into a Pulse XT 40. The epoxy part went fine no glue got into the nylon bearing that is glued into the tail. However when I went to CA the rudder hinges, a little CA ran into the nylon bearing that holds the tailwheel. I should have used vaseline to prevent this. I can move the rudder back and forth but it is still a little sticky. I tried a few drops of oil to the tailwheel bearing and this helped a little. Is there anything else I can do? Would CA debonder work?
Laird SS 11-17-2012 08:15 AM
RE: Help: I need to remove CA from nylon tailwheel bearing
That or acetone might work, however, I would try it on a similar piece of material that isn't part of the plane.
lfinney 11-17-2012 04:13 PM
CA debonder will work
eagledancer 11-22-2012 06:56 AM
sometimes heat will also loosen the bond, try a soldering iron on the wire, as you heat the wire work the tailwheel, once it breaks loose remove the heat and add some light oil into the bracket
kenh3497 11-23-2012 10:45 AM
Just redrill the hole for the wire with the correct size drill bit.
Ken
jaka 11-23-2012 12:48 PM
Hi!
I have answered this many times. But here we go again.
There is no better thing to use than pure nitro for loosen Ca glue. Debonder is just a waste of money and aceton takes tooooo long .
Simple as that!
All modelers should have some nitro at home!;)
bugdr 11-25-2012 09:00 AM
Thanks for all of the suggestions. I tried acetone, and CA debonder. I did not have any pure nitro to try. Both helped a lot. I also tried a little light oil. The rudder still slightly binds but there is not much resistance once it starts to move a little. I can't remove the tail wheel wire from the nylon joint to drill it out because of the way the tail wheel unit is made. I think I will just fly it the way it is for now.
