If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 6 of 6
  1. #1
    nitrosportsandrunner's Avatar
    Join Date
    Aug 2007
    skowhegan, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    xmod wont work!
    awhile ago, i bought a xmod skyline(the new skyline) and very shortly it stopped working. ive read that the controlers in the street series often fail. i dont want to put more money into this thing(car, plus motor, lights, 4wd, already spent $100)
    any ideas how i can fix.
    if not, anyone interested in parts?
    1/6 hummer crawler, HG P402, FJ40, Evader Bx, Kyosho Sand Master, Stampede, ECX Circuit
  2. #2
    Join Date
    Mar 2009
    Prairieville, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: xmod wont work!
    I've only run the gen 1 & evos ,not familiar with the new street series.The only problem i've had is the controller batt losing contact.
  3. #3
    Join Date
    Dec 2008
    Sunrise, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: xmod wont work!
    Well, let's try to diagnose what's going wrong...
    Does the controller still send a signal to the receiver? Does the ESC react to any commands from the controller? The easiest way to find out if anything is coming through is to put the rig upside-down on a table and see if any of the motors (servo, drive, etc.) are struggling to run. 9 times out of 10, it's usually due to a weak motor in the mix, not the signal coming in. If you get nothing at all, then trace back from there by probing the ESC leads going to the motors. The drive motor should be getting a voltage similar to the voltage of your battery... no ESC I know of reduces the voltage on the output side. If you get low voltage, you've got an ESC going bad. If you get nothing, then it's probably your receiver taking a dive (most likely a cracked crystal) as ESC's usually don't go dead all at once unless an internal fuse has blown (a simple fix), or you've fried the ESC (only happens when putting in voltages over 3VDC higher than the specs.) A VOM is a handy tool when you need to check this stuff. Good ones can run anywhere from $20-60, but you can find cheap ones for $3-5 at Harbor Freight Tools and sometimes at Sears in the "el cheapo" tools.
  4. #4
    Join Date
    Aug 2007
    skowhegan, ME
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: xmod wont work!
    the car does nothing. i turn it on, the green underlight comes on, but the front wheels dont turn nor does the motor. the car makes no sounds at all.
    it seems like the controler would be the issue, but i dont see anything wrong with it either. iv opened it up, and cant see any loose contacts or anything else obvious.
  5. #5
    Join Date
    Dec 2008
    Sunrise, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: xmod wont work!
    I think you might have a problem between the controller and the receiver. Lots of people have experienced problems where the wire antenna becomes unsoldered from the receiver. This would cause problems at long range, but wouldn't be an issue when you're right on top of the thing. I would take the controller into a hobby shop and have them check the oscillation rate of the crystal in the transmitter and receiver units. If the remote controller took a dive, the crystal could have cracked, thus leading to no functionality. Likewise, if the receiver unit got jarred to heavily, the crystal could have become cracked or unseated. A good hobby shop will give you the answers you need for free, and the crystals are relatively cheap since these units run on Amplitude Modulation. Since I don't have your rig sitting in front of me, I can't go much further than that, but, since you state the motors don't run, and it's highly unlikely that EVERY motor died at the same time unless you zapped the thing with too much voltage or drew too many amps, it's not likely your ESC is blown. Have you been able to measure a voltage coming out of the ESC? If you get a voltage, then your motors are fried. If not, the receiver is not getting a signal.
  6. #6
    Join Date
    Apr 2007
    littleton, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: xmod wont work!
    ok KE4QPF I don't mean to sound mean but xmods do not have a separate receiver and esc, it is a setup more closely related to that of a mini-z or micro-t, where the esc, receiver, and servo electrics are all in a single package, the only way to replace the electronics is to replace it in it's entirety, or if you are good with a soldering iron you may be able to replace parts on the electronic board until the problem is resolved, the weak point in the board are the FET's which a simple google search will show you what they look like and you are unable to replace the crystals on the xmod "street" cars.  I would go to radioshack and borrow the controller to their demo car and see if it works on your car, make sure that the frequency on the remote matches exactly to the one on the car, if that is the problem then buy a matching remote off of ebay.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
