Toy-Grade RC Products Post in here about toy-grade rc products and the mods you''re making to them. These typically fall in the sub $100 range.
RUBICON 1/10 NEWBRIGHT .. 4TH GEAR ..
Reply
Old 12-08-2009, 03:14 PM
texx
texx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RUBICON 1/10 NEWBRIGHT .. 4TH GEAR ..
I was the first to install a 4th gears on the Rubicon 1 / 10 ..
RATIO ((( 184 to 1 )))[X(]
8 tooth pinion ..
First, on BLACK-FLY,
and then YELLOW-CRAWLER ..
This as really a great pleasure to rework these RUBICON ..
texx is offline
Old 12-08-2009, 06:37 PM
texx
texx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RUBICON 1/10 NEWBRIGHT .. 4TH GEAR ..
I wanted a crawler, which could climb the rocks without problems ..
With the addition of a 4 th gear,
The result was impressive .. [X(]
[youtube]http://www.youtube.com/watch?v=sQ8C-eMH6Fc[/youtube]
And since, YELLOW CRAWLER is performing on the rock (ratio of 184 to 1)
I buy a used war tank, ($8.00)and I keep 2 motors 280 and all the gears .. [8D]
Two of them would fit very well with the gear RUBICON .. [sm=thumbup.gif]
I've installed, and my surprise was great .. [X(]
I have strengthened the ties of other gears for added security .. It still works very well ..
When I opened the differential BIG-CRAWLER,( 1/6 JEEP NEWBRIGHT )
I saw that there were 4 gear by diff ..
I knew that this crawler is quite powerful ..
And it is efficient (for a rc / toy) .. Doing mods, the rc / toys is really happy ..
[youtube]http://www.youtube.com/watch?v=cTG9_9dInKU[/youtube]
texx is offline
Old 12-09-2009, 10:32 AM
texx
texx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cobra69 ... has already been installed the 4th gear, and he has succeeded.[sm=thumbup.gif]
Cobra69 thread ...
http://www.rcuniverse.com/forum/m_8632683/tm.htm
See .. COBRA69 video [X(]
http://s338.photobucket.com/albums/n...100_0114-1.flv
texx is offline
Old 02-17-2011, 03:46 AM
Spiike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
texx i have this newbright jeep, see my thread, however i have added a 4th gear, the 4th gear is from another axle, using the smaller gearset, same as the 3rd gear in the stock axle, what ratio would this give me? i can't find the thread with you explaining the new bright axle gear ratios
Spiike is offline
Old 02-17-2011, 07:28 AM
texx
texx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello.. Spiike
Here's what I found.
Maybe this will help you.
You do a good job.
Good luck.
COBRA69 said ....
I have used different size compound gears for the 4th gear mod with good results,the only thing that changes is your final drive ratio.
46x10 10t pinion=199 to 1
46x10 8t pinion=248to1
42x14 10t pinion=130 to1
42x14 8t pinion=162 to 1
56x10 10t pinion=242 to 1
56x10 8t pinion=302 to 1
Hope this helps a little ......
And TEXX-GEAR......
4th gear = 34x10 .. + 8 tooth pinion .
Ratio= 184 to 1 for YELLOW-CRAWLER .
[youtube]http://www.youtube.com/watch?v=4XLrjRwpjA0[/youtube]
http://www.rcuniverse.com/forum/m_9215890/tm.htm
texx is offline
Old 02-17-2011, 12:08 PM
Spiike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I counted my gears, all stock, stock pinion on motor, the only thing I added was a 46/12 tooth gear for the 4th gear, thats the only reason i asked, cause i don't know how to calculate the gear ratio
Spiike is offline
Old 02-17-2011, 01:01 PM
texx
texx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spiike ..
I can not give you this information ..
Another member had calculated my ratio ..
You must calculate the number of teeth on each of the 4 gear ( + CENTER TEETH of each gear), and pinion too. Giving information about this forum, and another member is sure to calculate your ratio.
Gear 1= ? OUT/IN ..Shaft gear..
Gear 2= ? OUT/IN
Gear 3= ? OUT/IN
Gear 4= ? OUT/IN
Motor Pinion = ?
Sorry for not being able to calculate your ratio.[]
texx is offline
Old 02-17-2011, 03:39 PM
Spiike
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats okay texx, maybe somebody else can help, or i can find the equasion
Spiike is offline
Old 02-17-2011, 04:18 PM
cobra69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll try to post the gear formula for ya
cobra69 is offline
