New Bright FJ40 new owner
Target has the NB FJ40 crawler on sale for $41.98 so I picked up 2 for my older boys, ages 10 and 7. I haven't received them yet, but I wanted to pick up some more batteries so they can switch them out when they die instead of waiting 4 hours for a re-charge. Anybody know what the best place is for this? Also, is it possible to use a quick charger to charge the batteries?
When I was a kid I had a Tamiya Hornet and the charger I had was 15 minutes, it was great! I miss the old Hornet, but I see RC cars and trucks have come a long way since the mid 80's!
Thanks in advance for the advice.
RE: New Bright FJ40 new owner
69tr6r Welcome to our forum ..
You could intall two batteries in parallel or .. you get a good battery of 3500 mah ..
For the charger, your hobby store you will find some. [sm=thumbup.gif]
Good luck in your future mods, and post photos of your work ..
thank
The second battery installed in parallel, + / + .. - / - Used to give double the execution time
No battery..
With battery ..
2 th battery with wire + tamiya adaptor ..
The second battery ..
thank
No battery..
With battery ..
Approximately 15-20 minutes for 1 stock NB battery 600 mah (this is not the best battery) []
Then ... the execution time would be about 40/45 minutes with two 600 mah.
Best batterie ..3000 mah +..
Update - I received the 2 New Bright FJ40's and one of them has a bad battery, charged overnight and it doesn't move the truck more than a few inches. The other battery seems fine though. I thought the truck would be more capable, but I guess it needs some mods to be a better crawler.
On another note, I am going to return the one that has a bad battery, and when I checked out the Target web site, they are now reduced to $29.99. So I called and got a refund of around $11. Makes it a little better at that price.
Thanks.
Thanks.
HELLO .. 69tr6r ..
If the charger is good, it is possible that a battery is in trouble ..
The rc are just toys, we need their make some mods to make them perform.
Check mods YELLOW-CRAWLER, and also other members who were present rc / 10 newbright on the forum.
You can make a good climber, adding a 4th gear in the differential, or make it better, with some very simple mods .
.MOTOR / BETTER BATTERY / OIL-SHOCK / BEST TIRE / LOWER BODY / install an ESC system / ETC .. ETC
[youtube]http://www.youtube.com/watch?v=mlvQYAh9uso[/youtube]
i had no idea what you could do with a nb, iv'e bought 2 for the bodies, i trashed one of the chassis but kept the other. i got the rock crawler editions of the fj cruiser and jeep wrangler. this is what i do with those bodies
