Toy-Grade RC Products Post in here about toy-grade rc products and the mods you''re making to them. These typically fall in the sub $100 range.
New Bright Nitro Skidoo MXZ Snowmobile
Reply
Old 08-05-2011, 05:07 PM
nitrohead997
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New Bright Nitro Skidoo MXZ Snowmobile
I know this is a 9 month old thread, but anybody think they could give me directions on a build for one of these? thanks.
nitrohead997 is offline
Old 08-05-2011, 05:59 PM
traxxasslash12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi i mod and repair and paint rc things send more info of what you want done to and more pics and i see if i can do something cheep for you
traxxasslash12 is offline
Old 09-01-2011, 07:03 PM
Nancyhuang
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK! I hope your plan will be success!
Cheap Coach Purses
Coach outlet stores
coach factory outlet store
Nancyhuang is offline
Old 11-16-2011, 09:58 AM
G-17S
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bought the mxz 800 e- bay lets start here . what power do you want?
gary
G-17S is offline
Old 11-16-2011, 01:55 PM
G-17S
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
am using traxxas revo parts, and suspension parts 3.3 electric start, plentiful supply on e-bay cheap too!
G-17S is offline
Old 01-25-2012, 04:18 PM
  #31
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Check out my Sled! Sorry I know this is a really old thread, but I had to post it. Im having a little trouble with the Gear train and the suspension. I also have some new updated pics that have not yet been posted in the following thread:
http://www.rcgroups.com/forums/showthread.php?t=1411010
I will update it this weekend.
I am only 12, and I had to do this!!!!!
Brushlessed is offline
Old 01-26-2012, 05:45 AM
  #32
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi alexjschauer
Looks like you have all the right parts. Tell me what problems you are having and I'll try to help you?
TechyJoe is offline
Old 01-26-2012, 03:43 PM
  #33
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you!
I cannot find the right kind of shocks. Do you have any links?
I was also wondering what clutch you used.
My gear train is often slipping, (Probably because of my poor design), but my dad's an engineer I will have him take a look at that. I am thinking about scrapping the Plastic "Chassis" and creating an aluminum "frame".
Alex
Old 01-27-2012, 06:11 AM
  #34
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
alexjschauer
I read the rest of your thread. You did a great job on your MXZ build. What I like about you is that you didn't let others dissuade you from building your sled. A lot of people talk but you are a doer and made your snowmobile instead of asking others to do it for you. For that, I congratulate you.
P.S - I am also an engineer.
Now onto your issues.
Slipping
1) Your slipping is probably coming from the track slipping on the main drive wheels. You need to remove the drive wheels and flip them around so that there is more of the plastic lugs making contact to the track (not sure why New Bright didn't do this to begin with). You'll need to cut one of the plastic axles down some for this. I have a picture on my other XP build thread located at this URL on page 4. I'll also try to get some better pictures of this later today for you:
http://www.rcuniverse.com/forum/m_94..._4/key_/tm.htm
Suspension
2) Instead of building a whole new suspension, try strengthening the stock one. What I did was fill the plastic suspension bars with fiber glass and resin (Sig fiber glass kit) or you can fill them with Epoxy. One other thing you can do is to cut some metal rod insert some metal rod into the suspension bar slots and fiber glass/epoxy them in place. This works pretty well and will save you tons of time - now that it's winter and snow is here. Wait until summer to build a new suspension if you really want to go that route.
Shocks
3) For shocks, I pretty much used standard, cheap oil filled car shocks and they fit very well. Get the threaded ones where you can adjust the ride height with the thumb screw and set them to a lower setting (softer).
Clutch
4) I'll need to get back to you on the clutch bell. Basically, I tried to get one of the smallest clutch bells I could so I had more low end power.
TechyJoe is offline
Old 01-27-2012, 10:57 AM
  #35
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!!! I was wondering how to flip them around!! But that does slip, AND my gears are slipping. That plastic is no good.
Ok here is what I am going to do, since my motor has nearly fallen off because the plastic broke. (Don't worry, I'm not THAT stupid, I put many reinforcements before I mounted the motor, but the weaker spots that I didn't suspect broke.
This would be a lot easier if I had a 3D designing app on my computer, then I could just screenshot and post it here. But I will try to explain it.
I am going to rip out the little "box" where the drive wheel sits and where the motor sits on top of.  I will then (at my dad's machine shop at work) cut a piece of sheet metal, the correct size and shape.  I will fold it over so it makes the box shape. But, this pice of metal also extends all the way back to the tunnel. Itwill also extend up to the skis, (Don't know how I'm going to do it up there yet).My goal is to kinda have the Piece of sheet metal like a chassis, and then the body and the outside artwork can sit on the chassis. I have made bigger pulley wheels that ride under the seat in the tunnel for more track tension. I burned a few clutches because they were too big, I put the stock ones back in, and its sloppy. But I am going to make the modified ones smaller so there is no burning of clutches!
I can not drive it right now, because I have pretty much destoryed it because I did not reinforce it correctly. Live and learn. Well, now I will try this new plan, (I have it cut out on cradboard)  and see how it works.
The reason why my gears are slipping is because they are not mounted securely. And also because my motor is not staying where it is supposed to. It stays lined up with the gears, it just raises.
Hopefully I can get this peice of sheet metal made soon, so that I can run it!
Its no big loss though, because we had freezing rain, and then snow, (That was SUPER fun to drive on, I did cookies!) and then yesterday it got to a high of 40!!! So now everything is rock hard, and we only had about 4 inches of snow he way it is.
I notice my track binds much more in powder....
I want to make the front suspension aluminum/metal, but like you said, thats a summer project. Where did you make most of your parts? Home?
Please let me know what you think of this plan. My dad thinks it will work!
Thank you for your other tips, I will try them!
Thanks!
Alex
Old 01-27-2012, 01:02 PM
  #36
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh and also, I'd appreciate it if you could posts some pics of how you got the drive drum off of the saft. do you reuse the shaft?
Where do you find your subscribed threads? Like I know in Rcgroups it has a whole page that says which threads have been posted that you have subscribed to that you have not yet seen.
Old 01-27-2012, 02:58 PM
  #37
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
alexjschauer
Unfortunately, this is the engineering process. You try something and when it fails, you go back and make it better. I am currenlty performing the "exact" mods you described above. My black plastic cover also cracked, and yes, I too re-enforced it with fiberglass as well as sheet metal on top. I used a sheet of hobby shop bought aluminum and it fit the space perfectly. I bent the metel over my table top in a few places and viola! new cover in about 1/2 hour (not including drilling all the holes to mount it).
I don't have time right now to post the pics I took just a few days ago of my double sheet metal motor mount but I'll post them tomorrow sometime.
Your going to need to build a better drive train to hold the gears in place.
For the hex drive shaft, I drilled a small hole in the platic body in order to slide it out without bending it. I hated to do that but it seemed was the only way to remove it.
To see your subscribed forums, click the forum drop down at the top of the page. Select "My Forums" and scroll all the way down to the bottom of the page where they will be listed.
TechyJoe is offline
Old 01-27-2012, 03:00 PM
  #38
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh, and that clutch bell is 14 tooth 32 pitch.
TechyJoe is offline
Old 01-27-2012, 04:49 PM
  #39
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks!
Yes, the black plasitc was cracked...into 4 peices!! I had the whole thing wood reinforced AND sheet metal covered.All of the red plastic around it is about to fall off, its hanging by a thread. I'm going to try the sheet metal idea, and if it doesn't work, so what? Try again! I've got plans, and the cutter at my dad's work makes slick work of sheet metal. They also have LOTSSSS of material...for free! So it doesn't hurt to try!
No need to take pictures of the drive wheel, I got it figured out. It's a press fit.
I will update pics of the sheet metal thing installed when I get it made. I will also post a pic of it uninstalled. Along with the sheet metal comes a new drive train.
Thanks!
Alex
Old 01-28-2012, 06:55 AM
  #40
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pics of the following:
1) New aluminum tunnel cover
2) Tunnel cover installed from top and buttom views
3) New tunnel cover with the heavy metal motor floor board installed
4) Picture of how I used some threaded rod to attach the shocks to the chasis
ID:	1720126   Click image for larger version
ID:	1720127   Click image for larger version
ID:	1720128   Click image for larger version
ID:	1720129   Click image for larger version
ID:	1720130   Click image for larger version
ID:	1720131   Click image for larger version
TechyJoe is offline
Old 01-28-2012, 07:34 PM
  #41
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you so much!!!!!!!!!!!1
Old 01-30-2012, 05:30 AM
  #42
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you try to explain how to upload pics?
Thanks!
Alex
Old 01-30-2012, 06:09 AM
  #43
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sure it's easy
Don't use the "Fast Reply" option at the bottom of the post page. Use the "Post Reply" button at the bottom left of the screen.
This post screen has an option link at the buttom "Click here to upload images and files". Then just use the "Select a file to upload" screen to select the images from your computers hard drive. You can add up to 12 pictures at once.
TechyJoe is offline
Old 01-30-2012, 01:04 PM
  #44
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OOOh duh. Thanks!
I have posted a pic that you posted, but I edited it to shopw whats wrong with my sled. The bars where the arrows are pointing are catching on the drive spurs on the track. Whenever I go over a chunk of ice, it catches. I also noticed that the track binds a ton in powder. Are you having these issues? But Its an easy fix. I am going to cut them out and replace them with bolts and nuts slightly higher in the suspension.
Alex
Old 02-01-2012, 05:24 AM
  #45
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need to fix your suspension as outlined on page 1 if you are still using the stock suspension. This will remove most of your issues such as track slip and binding. I run my snowmobile mostly on flat snow (which we have little of) so I can't say I have experienced the binding you described.
TechyJoe is offline
Old 02-01-2012, 09:19 AM
  #46
sumrcruz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made one into nitro . Put a traxxas pro 15 in it and up grtaded the suspension . It took a long time but looks awesome .
sumrcruz is offline
Old 02-01-2012, 10:43 AM
  #47
sumrcruz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's some of the engine pictures . I got the exhaust and motor to fit perfect under the hood , made it look like a real snowmobile .
ID:	1722016   Click image for larger version
ID:	1722017   Click image for larger version
sumrcruz is offline
Old 02-01-2012, 11:00 AM
  #48
sumrcruz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I installed some new LED lights through out the sled and got the exhaust to come out the bottom.The rear and front suspension has also been upgraded with Traxxas parts . I made a pair of ware bars ( scags ) out of some 1/8 inch galvanized wire .
ID:	1722024   Click image for larger version
ID:	1722025   Click image for larger version
ID:	1722026   Click image for larger version
ID:	1722027   Click image for larger version
ID:	1722028   Click image for larger version
sumrcruz is offline
Old 02-01-2012, 02:45 PM
  #49
Brushlessed
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh awesome! Thanks Joe!
Looking really good sumrcruz!!! I wish I had the time/tools to make the mods you described!
Old 02-01-2012, 03:53 PM
  #50
TechyJoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sumrcruz
Awesome job man! Quite the little club we have going on here.
I love the belt drive system. Would you mind sharing more info on the parts you used for that?
You also did a great job on those upper and lower links.
TechyJoe is offline
Reply
Display Modes
