snow + t-maxx
snow + t-maxx
how do i fully waterproof my t-maxx. i have it totally standard at the moment but i having been using it in the snow and things have started going wrong, the foward reverse servo is just twitching pulling it in and out of gear and the throttle servo seems to have a mind of its own so im guessing the snow has caused the problems, i want to make it waterproof but with a low budget, any help/advice appreciated
RE: snow + t-maxx
ORIGINAL: jord_trx2.5
RE: snow + t-maxx
ok thanks for advice, i know its not possible to fully waterproof the truck because of things like exhaust and air intake just want to make the electrics waterproof so that it can handle the snow, im not planning on running it through lakes etc..
RE: snow + t-maxx
RE: snow + t-maxx
Snow + T-Maxx = problems. Nitro engines really don't like very high or low temperatures. And unless you have all stainless steel or titanium screws things will start to rust which can caus some major issues when you try to disassemble your truck. As for water proofing I believe you should check you tube for videos by a guy named squirrel. Or you could upgrade to some water proof servos.
MN
RE: snow + t-maxx
RTV sealant or plasti dip (available at any hardware store) for the servos. Then put your receiver and battery in a balloon with a zip tie around the wire. It also helps to cut a used sock and put it around the engine cooling head. That will keep temps more stable and will help to protect the head frok the temperature swing if you flip it in the snow.
http://www.youtube.com/watch?v=YWncP...eature=related
NY
RE: snow + t-maxx
Definitely wrap the head in something and richen the needle. You can help your electronics survive, but your wheel and diff bearings will gone in no time.
My Feedback: (31)
KY
RE: snow + t-maxx
Bearings dont just fall apart at the first sight of water. No, they wont last as long, but they should be rubber sealed which will keep most of the water out since snow isnt going to be like driving in water.
RE: snow + t-maxx
ORIGINAL: cummins driver
Its not going to fall apart or break at the first sight of water. Cold weather however will make the plastic parts more brittle so crashes can be more "lethal". Still - I wouldn't be afraid to run in rain or snow.
RE: snow + t-maxx
ORIGINAL: ReaperGN
Snow is worse than just water. Especially when it melts and finds a nice crevice to re freeze in.
RE: snow + t-maxx
Running in snow will make every bearing and screw wear faster. Blowing it off with air wont replace the oil. If at all possible you should avoid running in rain or snow. Very few rc vehicles have a owners manual that says go run it in snow for a good reason.
RE: snow + t-maxx
ORIGINAL: ReaperGN
I'm done. I run in snow and my cars/trucks do not suffer any ill effects because of it. I take 'em apart once a year to clean them, re-lube the transmission, and oil all of the wheel bearings.
Running unbalanced tires will wear your bearings out faster though.
NY
RE: snow + t-maxx
I have a crappy revo 2.5 chassis that I use for that. It gets all the hand me downparts off my good rigs. Even so, I rarely run in the winter, let alone snow. My good rigs are in storage withmy good engines removed and 'pickled'.
RE: snow + t-maxx
Just run the damn thing and have fun with it . Of course i run some of my bashers in the winter/ snow we have fun . I keep one at work and so do some of the guys at work and we run them after work whenever we feel like it snow or not .
RE: snow + t-maxx
i run in water ALL the time ...
Its called PROPER care .
I have not needed to replace NOTHING on my truck.
[youtube]http://www.youtube.com/watch?v=z1V-9TvFUPk[/youtube]
[youtube]http://www.youtube.com/watch?v=KbFuTiZxF5E[/youtube]
RE: snow + t-maxx
proper care
and Proper maintenance when you do.
i did not figure i needed to say " maintenance " as that IS a part of Proper care.
Logicly
and I did notthink i was talking to 10 year old kids.......... sorry........
If you drive a brand new car or a classic car all day on salty roads
Do you not wash and clean it at the end of the day?
Logicly
