emaxx???
emaxx???
emaxx 14.4 replaced evx motors recievertransmitter crystals batteries. motors still wont turn over steering works and shifter works!!! anyideas? only thing maybe my wireless internet i think of is interfering idk any help appreciatted thank!
RE: emaxx???
I would start by using wire leads to make sure each motor works. Just attach the leads to a good battery and then to the terminals on the motor after you unhook it from the esc. If they work then your problem may be the esc.
RE: emaxx???
If your steering works plug the esc into the steering port on your receiver and see if that will send a signal to the esc. And are you getting any lights on the esc? It should change colors if the esc is getting a signal.
RE: emaxx???
yes light turns green . forward and reverse .i hooked up a voltmeter to esc and pulled trigger no volts coming oout but i am getting signal
RE: emaxx???
ORIGINAL: sjhm9102
RE: emaxx???
If the esc shows a signal and the motors work then the esc must be bad. You have already tested the motors and radio so the only things left are the esc and battery's. But if your battery's can power the motors and servos then it has to be the esc. When setting up the new esc did you set the max throttle and brake? Even if you didn't I would think that the volt meter would still pick something up. If you recently bought a new esc then you might want to return it or send it to the manufacturer if its under warranty.
RE: emaxx???
something is not adding up here? i really doubt 2 esc's are going to have the same problem, allthough it is possible. go over all the basics. are the motors wired properly?
RE: emaxx???
By the sounds of things he has brushed motors. So it would be very hard to wire it up in a way that they don't respond to the esc. Unless he has not reconnected the motors to the esc.
RE: emaxx???
i know this sounds crazy but maybe he has one polarity backwards, causing them to fight each other? i really doubt that though as he would hear them fighting each other
OR
RE: emaxx???
My friend bought a emaxx that wouldn't run and he took the motors off and realized on was a reversed ervevo 550 and no it would no break the spur gear.
NY
RE: emaxx???
If the mesh was good they would never strip a spur gear. If two motors can't strip a spur gearwhen you hold the truck down with the slipper locked, they won't strip it trying to run in opposite directions.
RE: emaxx???
this was all tested at 5.99v each battery so i charged the batteries to 7.2 each and it smoked the new esc so i shipped it back thanks btw the motors are bothe same direction they spun really slow when the esc burned up but turned fine hooked up direct thanks
RE: emaxx???
traxxas wants 50 bucks to replace the 3014 evx they are not covered under warranty anymore so dont buy one if your thinking bout it! im currently bidding on an evx2 waterproof will it fit in a 3906 old emaxx 14.4v? screw in stock location?
