Traxxas T-Maxx Roll cage What do U think?
Hi,
This is our first (I hope not the last) roll cage for the T-maxx. Made from 6mm outside /4mm inside STAINLESS SEEL TUBE!!!
Welded with TIG weld. Sits on springs to make less damage from bad roll lol. Still have acces to do things underneath.
NOT BEEN PAINTED! This is the steel itself.
Weight: 256gramms only
Please tell me what U think. I hope we can make some tests and record with camera, that goes on youtube. I'll let U know.
Thanks for looking
Samm
Thanks for looking
Samm
RE: Traxxas T-Maxx Roll cage What do U think?
Belive me. That tubes not bend thas all. Stainless steel. So strong.
But Will see after the tests.
Stainless is not that strong. I would make another form regular steel, find a way to make it lighter, and ditch the springs and use a different mounting system. Also how you support the tube makes a big difference. Play with your design and do some impact testing.
First I'll test this how it is. This tube is much stronger then the mild steel.
I don't wana use plastick body shell whenn this is on. I thinking some fabrik "clothing" to protect from dust but this is just plan yet.
I think the 6.5 kgs from 2.4 meters a bit too much to test. It isn't made for protect the car from FULLSPEED WALL CRASH. I think the car abot a half of this weight an U not really jump to 2.4 meters with...
Anyway. I might do it to see what the reaction is. But wont do with the car hjust with the cage. With the car I think do better anyway, because the springs on the cage and on the car as well....
Sammy
Sammy
Here is a thread with various roll cages. Take a look and see how others are building them.
http://www.rcuniverse.com/forum/m_10346432/tm.htm
do you plan on trying to sell cages?
if so you may want to plan on what heights other may be jumping.
the heights i have seen some jump (close to 25-30 feet in the air), that won't take a lid landing of that calibre.
just sayin'
just sayin'
ORIGINAL: 1Sammy
I think the 6.5 kgs from 2.4 meters a bit too much to test. It isn't made for protect the car from FULL SPEED WALL CRASH. I think the car abot a half of this weight an U not really jump to 2.4 meters with...
Sammy
Sammy
Ill have one T-maxx 2.5 as well. I might test wit that from 2.5 meters drop to upside down. Thats make a good test?
Sammy
Sammy
It would but I wouldn't want to crash test an actual truck in case the cage doesn't hold. Dropping from eight feet upsidedown will most certainly break an unprotected Tmaxx. That's why I suggested dropping something that weighs about the same on an unmounted cage.
The only think about this is the springs. 4on the cage and 8 on the truck. Without the truck non of the springs works thats all. With the truck all 12 springs take some off from the power...
Sammy
Sammy
VA
Just go make a video bashin it (let us see the video)...if it holds ill buy one...im needin one for my t-maxx neway.....
if it dont work.....well ill just sell you my brand new t-maxx so you can redo ur cage set-up!!!!!!
Spring mounts work as long as they are mounted to something very strong. If not the springs could possibly break the mount. I like how my HBZ cage mounts to the bumper mounts. If they break its no big deal and they will probably last long enough to help the truck survive. Mounting to the shock towers could be bad because if they break shocks and bulkheads may be affected. I would at least go to the chassis rather than the shock towers.
I don't want to make any complecated fixings on it but I might do something to fix to the bumper mounts. First I just want to got time to trie dis out...
Sammy
Sammy
