gearing
gearing
what is best gearing setup for my tmaxx 3.3 for the spur and clutch bell gear, the teeth i should use , out where i live our yards are really ruff and bumpy. cause of the fact i live in southern ohio out in the sticks so to speak, i was wandering what the best gear as in tooth to tooth setup would be best to give good performance and speed over my terrain.
NY
RE: gearing
On a stock 3.3 I'd use a 20 or 21tooth clutch bellover rough / bumpy terrain. That gives the truck plenty of low end power and it's still pretty fast.
RE: gearing
mclovin atm i have the stock clutch bell gear on my tmaxx 3.3 but i had to replace the stock spur gear cause the teeth got ate off of it, i replaced it with an 55T steel spur gear, is that setup alright for the terrain i have or should i get an diff spur gear with diff teeth?
