t maxx clutch question??
VA
Due to my Tmaxx stalling when i brake.. I removed and inspected the cluth assembly. The spring and shoes are intact but I noticed that with one of the clutch shoe holes i could see part of the spring...it makes it a little hard to install on the flywheel pegs..should I replace the shoes or is this acceptable or might lead to it shutting down when the brakes are applied..The spring still sits well below the edge of the shoes but I dont remember ever seeing part of the spring before through one of the mounting holes of one shoe?? Thanks Semper Fi
RE: t maxx clutch question??
thats an easy fix, its not your shoes, look at the carb and press the breaks, the carb is getting pushed in when u allpy the breaks. Look at your spring thats on ur throttel tighten that a bit and you should be fine, that way the spring is closing the carb all the way and when u press the break its not closing it while breaking, also open ur carb just a bit more after u tighten the throttel spring
The spring looks like this
or uou can put one of these springs that go on the engine carb it self.
ORIGINAL: huey267
