i'm baffled !!
and all of a sudden the rear end stop moving, i had front wheel drive not four wheel drive.
i took the diff apart and the trans and i can not for the life of me figure out what the heck happened. the gears in the diff and the trans are fine and not chewed up or missing teeth.
can any of you guys give any suggestions to check other than what i have already!! i also checked my output shaft and that is fine to. i put the diff back together and all the gears move good by hand.
Thats why i thought i stripped a gear in the diff.i am putting it back together to give it another try to see if something just came loose.
i will let you guys know what happens. it didnt lock up eitherjust stopped moving, like i stripped a gear in the diff, actually the drive shaft from the trans to the rear end wasnt spinning either,
but it wasnt locked up either, thats why its so baffling to me.
four tec for the motor, to a friend of mine. i am actually looking at a 3.3 roller that needs tires, RX/TX and motor for like $190
my 2.5r still has a lot of life left in it. i dont know what to do about this issue. i am putting it back together to see if it works.
i will definately let you guys know what happens, maybe i can get the wife to video tape it if it is doing the same thing
when i get back together and post it.
have no clue whats wrong with mine, put it back together and still only front wheel drive. nothing broken, no stripped gears, if there is something i missed oh well,
all pins and clips fine, cant figure it out, and im done trying. got a good deal on the motor and the truck, spending under 150 for everything. it would cost almopst as much for a
new trans and diffs.
A new trans and diffs would be about 50-60 bucks if you looked around.
just cant figure out what happened. thats why im so baffled. the roller i got has no 2nd gear in the trans, but it runs good.
i am thinking of selling all my tmaxx stuff to get a new one, i have enough parts to make two trucks now if someone can figure out what happened to
my fouir wheel drive.
everything again i guess.
It wouldn’t be a bearing…If the front wheels are spinning that means the output shaft in the tranny (which is a solid shaft in a Tmaxx) is turning. If the rear center shaft is not turning it can only mean it is disconnected from the output shaft.
Put the truck on the ground, lift the front wheels and push/pull the truck. If the front wheels do not turn and the rear center shaft does it can only mean the shaft is not connected to the transmission output shaft. Check the screw that holds the shaft yoke to the tranny shaft, the screw pin can break but still look intact.
i love working on these things, its very relaxing to me.
