now these dont fit.......
seeing they are not long enough now, would i be able to get the traxxas red linkage to fit?(if so what size) i love how those look and apparently they are alot stronger also
do i just screw it to either the top or bottom?
its not long enough.........
Banned
RE: now these dont fit.......
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHGC9&P=7]These[/link] will help you out with the fist picture and I don't think you can get longer toe links. That is a strange steering set up you have there.
The aluminum links for the new Maxx trucks fit without issue. IIRC the new knuckles use a different length tie rod than the older 2.5 style. You will need the "hollow balls" (the part that sits in the rod end) to install them, none of the tie rods come with them. Go on Traxxas.com, look up a new Maxx and under accessories you'll find the correct tie rods for the front and rear.
Since you have the 3.3 spec axle carriers and wide a-arms you will need the 3.3 spec/length toe links.
The red toe links are available in the size you need.
i'd really like the red 'toe links' can i get those for front and rear?
and what size would i most likely need? 9teres like a million different sizes)
i found a old revo linkage this work work in the rear, but i want to get the red linkage. heres a picture but i dont now what size i would need.....
Part # 5141R - Front
Part # 5143R - Rear
Part # 5355 are the hollow balls you will need.
The toe links also come in black, change the R to an A in the part #.
Part # 5143R - Rear
Banned
I'm confused does the O.P. want maxx turnbuckles or revo turnbuckles?
Here are the revo turnbuckles if that is what you want. They are 128mm in length.
Black - Part# 5338A
http://www3.towerhobbies.com/cgi-bin...I=TRAC5310&P=K
Red - Part# 5143R
http://www3.towerhobbies.com/cgi-bin...I=TRAC5340&P=K
Not sure if there is any difference in strength but I have the black ones on my revo and I like how they look a little chunkier then the red.
Black - Part# 5338A
Red - Part# 5143R
