Traxxas Summit
#1426
AL
RE: Traxxas Summit
Nice. U might want to go ahead and get some spare bearings! I heard u say something about losing connection, it does when the antenna goes under water. The first time i took mine in a creek i found that out the hard way...had to go in knee deep to get it!
#1427
RE: Traxxas Summit
Ya ordered some for that reason. I read in the manual about that signal thing and it says simply walking closer can regain connection? That's what it looked like I did yesterday and it worked apparently so not sure.
#1429
Banned
RE: Traxxas Summit
#1430
RE: Traxxas Summit
Took out the summit to local park in the dark. Only summit in the dark + two rabbits to chase! That was fun! With my new 5000mha 40c lipos the truck drives very well.
Only thing I noticed that front right wheel hub is a bit wobbly. Maybe it is time for big overhaul soon or then I just drive it until something big breaks. That just seems to be very hard to do?
#1431
RE: Traxxas Summit
So I was hitting that same trail again today. I went to climb some rocks in high grass and my buddie who was filming siad it may have cought up in some type of fence. After that was making the clicking noise. Im thinking something broke. As im currently tearing into it I thought Id post a vid of it in case someone has a pin poin of what the problem is.
http://youtu.be/rr84bQYjlas
Heres the video of the actuall accident of when the noise started....
http://youtu.be/hl0bZ47gHXQ
#1434
RE: Traxxas Summit
http://www.ebay.com/itm/MIP-9168-Spl...item484bcec8bf
This the steel drive shaft you talking about?
#1436
RE: Traxxas Summit
Ya sorry I have those bookmarked, I think I'm confused. I thought those were the half shafts from the gear box to the tires, not the main shaft itself.
So basically, those will replace my drive shaft complete. Anything else I need to complete the change out?
#1441
RE: Traxxas Summit
Ya figured that. Im looking at putting the single dewalt motor in at a minimum. Get the steel shafts and the slipper clutch upgrade you mentioned. Due to those tires you linked a bit ago, the giant tires with those prototype chain studs. I just got 2 of them from the owner. Cept their on the stock tire/rims with sealed foam installed. I'll be doing testing for him with just the reader set. That's why I was asking on what other common wear items might need upgraded to steel.
PS. You live in Dothan? I used to live in panama city, stationed at tyndall AFB and used to drive to or through Dothan all the time.
#1442
AL
RE: Traxxas Summit
Yeah man. PC is just an hour and a half drive away. I also want a single dewalt setup. Ive heard u gain like 5 mph which would be perfect for the summit.
#1443
RE: Traxxas Summit
ORIGINAL: Summit is Beast!!!
#1445
RE: Traxxas Summit
That's right 18 or 19, remember it's a 32 pitch with a 5mm hole. It can also be referred to as a "mod .8", same thing for our machine. I run the 18 with stock Canyon tires and Proline Trenchers.
#1446
RE: Traxxas Summit
Roger that. Im sure ill be dumb and go dual dewalt motors becuase I can. Stock tires with closed foam and the protoype chains with studs. And maybe ill get teh big joes on the front.
#1447
AL
RE: Traxxas Summit
What is this? Ive never seen it b4.
Traxxas 5697 T-Lock Electronic Diff/Differential Controller: 1/10 Summit New
http://bit.ly/WPPz2n
#1448
RE: Traxxas Summit
The electronic diff T- lock was used in the original AM radio summits. It divided/ diverted the 3 way differential locking switch signal towards the rear of front differential as selected.
Not used in the current 2.4 ghz summits
#1450
RE: Traxxas Summit
ORIGINAL: Xseeker
