emaxx 3908
My Feedback: (27)
NH
emaxx 3908
I just got the ok to buy the new emaxx but do you guys think it is worth the $600 or should i just get the 3903 for $400 probley buying this week what do you guys think.
RE: emaxx 3908
ORIGINAL: billdozer1983
RE: emaxx 3908
yes it is worth it. by the time you buy the brushed version and upgrade to brushless you will spend more money than just buying the brushless version to start with. the truck does have some weak points but are easily fixed, so yea i say go for the brushless version.
RE: emaxx 3908
WA
RE: emaxx 3908
ORIGINAL: LaTuFu
Except you can't get a Flux or an ERBE for $600...
But you can get a Thunder Tiger MT4 G3 for $500! Better truck than all 3 and cheaper, too!
My Feedback: (27)
NH
RE: emaxx 3908
Thanks for all the info. So now i got 1 more question before i order it. What makes the savage so much better than the emaxxbecusethe savage is cheeper. But mybig thing is parts and all my local hobby shops have traxxas parts in stock. But if the savage is alot better and cheeper i might go that road.
My Feedback: (27)
NH
RE: emaxx 3908
Thanks for all the info. So now i got 1 more question before i order it. What makes the savage so much better than the emaxx becuse the savage is cheeper. But my big thing is parts and all my local hobby shops have traxxas parts in stock. But if the savage is alot better and cheeper i might go that road.
NY
RE: emaxx 3908
Yeah save and get the ERBE. but to answer youe question the savage is much tougher then the E-maxx supposedly. and the suspension is better also
My Feedback: (27)
NH
RE: emaxx 3908
Ok now that i have looked at a thousand diffrent reviews i think i might go with the savage 2350. it is a little cheeper and it sounds very durable. But the E-Maxx is a thousand time easyer to work on but it needs rear bulk heads and a arms and shock towers right out of the box. THIS IS SO FRUSTRAITING TO MANY CHOICES AND UPS AND DOWNS.
My Feedback: (16)
RE: emaxx 3908
I don't get all the E-maxx put downs... I've got a 3908, It has a Novak HV Pro esc and HV 6.5 motor on two 2S lipos.I bash it pretty good and I've only had to replace one upper front arm. Lucky I guess,Hmmm.
RE: emaxx 3908
ORIGINAL: oldbugs
RE: emaxx 3908
ORIGINAL: oldbugs
My Feedback: (27)
NH
RE: emaxx 3908
I just ordered my new truck it should be in onfriday after a lot of thinking and reserch the HPIsavage flux hp won. Thank you every one for all of the info and help. I will post a pic when i get it.
RE: emaxx 3908
Oh wow, I forgot how shiny they are when they're new. Congrats! From my Flux experiences I will tell you that the body will not stay that pretty for long. Monster trucks are fun to drive and even more fun to drive hard! With that, the truck will end up on it's lid frequently and that kind of action tears bodies up. Use that as an excuse to buy a new one you can paint yourself. On average a new shell runs $30-$40.
Oh, one last thing. I strongly encourage that you take time to balance the wheels/tires. You can find a thread on that here on RCU. Basically you stick small amounts of clay inside the rim to correct any weight imbalances. This will take strain off the motor, ball bearings and the whole truck really and help you run smoother and faster. I almost say it's mandatory if you want to run 2 3S LiPo packs.
WA
RE: emaxx 3908
I remember when my flux looked all shiny like that.....for about 5 minutes I pretty much trashed my body the first day. Be sure to lock your slipper down tight! And be sure to loctite the pinion gear grub screw. Also unless you want to go through pinion gears you should convert to a plastic spur gear. Have a blast with it! I know I still do after 2 years!
