My new emaxx build. Needing a 3908 chassie and trans.
Well i'm starting to upgrade my emaxx. It's an older 3906 model with all alum front and rear(everything is upgraded on those parts) and has a stock chassie/trans. Problem is i ordered a new servo and brushless system.
I'm looking for someone who has a brushless emaxx 3908 trans and chassie. The more complete the better. I know ebay has them listed but rather buy everything from one person.
Here are some pictures. I need new wheels and tires too. let me know what you guys think and if you have any parts i could use. I'm trying to get this running and all the bugs worked out by fourth of july to run with the family.
NY
RE: My new emaxx build. Needing a 3908 chassie and trans.
ORIGINAL: 87burb
ORIGINAL: trax de max
have you changed diffs
no need to limit the search for 3908. (3905,3903,3908 the same just different radio system, and motor in 3908).
I have looked at those wheels...i like them alot and the X version too. If i can find a good used set, it'd be my best bet.
NY
I will have to hold off for now. Found a guy one bay with the chassie so i've spent to much this week haha. Hopefully i'll get some new pics for you guys this week. Thanks for all the help so far.
NY
ORIGINAL: 87burb
No its a stock plastic one. I can't afford the $100 on an flm right now. Not sure I want the alum chassis I hear the bend easy. I haven't bent an alum arm yet but im not brushless yet.
ORIGINAL: pyromatic177
It's an aluminum chassis?
ORIGINAL: 87burb
NY
ORIGINAL: 87burb
ORIGINAL: 87burb
Where did you buy your alum upgrades for your emaxx? I was think about upgrading mine. Do you have some links?
Here's what I did to mine, truck is really tough now, and I have had good luck with integy biggest thing it blue lock tight where bolts go into aluminum
http://www.rcuniverse.com/forum/m_10...m.htm#10920970
What motor and ESC did you put in there? Pinion size? Do you like its speed? I just got an Earthquake 8e Brushless and I like to race them with my friends but the Emaxx is about 1/3 the speed of the brushless.
The new emaxx comes with a castle creations brushless system installed, capable of running 6 lipo cells
Do you know about how fast you get it going? And are those the stock shocks? Alluminum or 3908 chassis? Could I use:
http://www.hobbyking.com/hobbyking/s...dproduct=14632
http://www.hobbyking.com/hobbyking/s..._Car_ESC_.html?
BTW thank you for the info so far I am very new to RC cars.
Do you know the KV on your motor? I was looking to get around 60 but I heard I need to upgrade other things on it. Do you know what those things are?
What would break.?? Well hit a curb at 60 and watch the truck explode into pieces. Hit nothing and nothing will break. Running a more powerful system will wear the driveline out faster. Less power=less wear. More power=more wear. (diffs, driveshafts, axles)
Haha thank you. My old shocks are getting a little bit rusty do you have any ideas on some big bore shocks for it?
Let me rephrase this actually. My shopping list right now for my emaxx 3906 is:
http://www.integy.com/st_prod.html?p...885&p_catid=75 x2
http://www.rc-monster.com/proddetail...LM19000&cat=47
http://www.towerhobbies.com/products...csec6201m.html
http://www.rc-monster.com/proddetail...LM17001&cat=47
http://www.rc-monster.com/proddetail...LM18001&cat=47
http://www.rc-monster.com/proddetail...LM12015&cat=47
http://www.rc-monster.com/proddetail...LM12005&cat=47
http://www.rc-monster.com/proddetail...iffcase&cat=47
http://www.rc-monster.com/proddetail...LM15600&cat=47
http://www.rc-monster.com/proddetail...LM15500&cat=47
http://www.amainhobbies.com/product_...inion-Gear-26T with a 66 spur
http://rcrun.com/Emaxx-aluminum-chassis-flm10900
http://traxxas.com/products/parts/servos/2075 x2
Is that all that I need to get a boss Emaxx?
