Tmaxx Engine Issue
MN
Tmaxx Engine Issue
Hey all, been running nitro cars for years but ran into a problem with my trx 2.5. I had a ported 3.3 in my tmaxx and broke my piston rod so I put in an extra 2.5 I had laying around. Broken in but no more than 3/4 gallon through it.
I reset needles to factory and fire right up and ran great. I went to tuning but after 4-5 WOT passes it bogs and dies. I have adjusted the needles both ways and no difference. It wont start up again until the engine cools, and then rips for 4-5 passes and then the same thing. I opened the high speed by 1/2 turn just to see and same thing. Opened low speed 1/2 turn and same. Doesn't seem to make a difference. Am I losing my tuning skills or is something else going on?
Thanks!
Thanks!
RE: Tmaxx Engine Issue
richen it up, check/replace fuel lines, check tank for good seal, check to see if starter shaft has alot of wear- this will cause a air leak, check front bearing play.
there is something wrong with the tank/lines that probably killed your 3.3
