Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
FLM Stampede build help!?
Reply
Old 05-10-2013, 08:31 PM
Exclusive Pede
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default FLM Stampede build help!?
I want a reliable, strong and fast truck problem is I was running it the other day for the 5th time for about 30 mins and the motor fried... I have a million different ppl pushing and pulling me in diff directions so I need some help please, only is NOT an issue....
Things to consider
-full FLM 1/8 scale conversion on my stampede, now obviously bigger and heavier
-I have the vxl3 system with the esc fan
-my spur gear is 56 teeth
-pinion is 18
-I run a 6400mah 11.1 3 cell venom lipo
Is the Vxl system fine or should I do a bigger motor considering its a bigger and heavier car?
Is the battery fine or should I run a 2 cell? I was told 3 cell is too much?
Are the spur and pinion gears fine or should I go higher or lower? (The current ones were recommended to me by the hobby shop although I think he was just trying to take my money instead of being really helpful)
All input is appreciated feel free to ask any other questions that may help the responses, remember I want it to be fast nothing crazy but quick, strong and above all reliable enough to play withal long as I got batteries for all day fun...
Thank you in advance!
Exclusive Pede is offline
Old 05-11-2013, 04:33 PM
JoeMaxx
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: FLM Stampede build help!?
The VXL system is about a 3500 KV motor and will support the 11.1 Volt 3 Cell LiPo battery packs. The VXL is installed in many Traxxas Trucks. Lower gearing would be best if you increase the weight or choose a 1/8 Scale motor.
Most 1/8 Scale Buggies and Truggies are running a higher Torque 120 AMP 2200 or 2650KV motors because of the weight of these 1/8 scale. WIith one of these motors you can run higher gearing.
Running a3 Cell battery on the factory motor is why they are burning up so fast as you have already seen. Too much power to the motor will get them veryhot and fry them
http://pics.stampedeproject.com/RCCAR-FLM-Stampede.html
Velineon VXL-3s ESC;
Auto-detects and compatible with brushed, brushless and sensored
brushless motors
Compatible with NiCd, NiMH (4-10 cells) and 2-3 cell LiPo battery
packs-two stage low voltage detection for LiPos
Three driver profiles-Sport, Race and Training Modes
Gold-plated motor connectors
Built-in output for optional auxiliary cooling fan
Velineon 3500 Brushless Motor;
10-turn 3500kV
Optimized for extreme power and efficiency in 1/10 scale vehicles
Ultra high temp neodymium magnets, high-speed ball bearings
Precision balanced rotor
Traxxas High-Current Connector
Reverse polarity protection makes backward connections impossible
Compatible with high-current 12-gauge wire
Gold-plated wide surface terminals
Textured surface for easy gripping
INCLUDES: Velineon VXL-3s ESC, Velineon 3500 Brushless Motor and high-current
connector
REQUIRES: Installing in vehicle
NiCd, NiMH (4-10 cells) or 2-3 cell LiPo battery
JoeMaxx is offline
Old 05-11-2013, 06:32 PM
Exclusive Pede
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the useful feedback, I am going to do some gearing changes and run 2s lipos for now
Reply
Display Modes
