Tmax 2.5 Won't Shift
RE: Tmax 2.5 Won't ****t
Here is your problem....The spur gear is slipping..This is why it will shift when there is no load on it...After you tighten the spur gear if it still does not shift take the spur gear out and replace those little fiber pins in the holes around the center of the gear..Also instead of putting a pin in every other hole put one in every hole.
Hope this helps.
Hope this helps.
#32
alright guys got the new part the other day it now shifts.. but i have extreme lost of power.. i am talking i can ride my bike faster then this thing now..
#37
dont even waist ur money on an piston and sleeve just get a new engine cause if u dont the same probs goin to happen again and did u drop ur maxx at that LHS that didnt think to call traxxas
#41
My Feedback: (8)
I am suprised no one said this yet... but CHECK YOUR CLUTCH!!! it might be slipping inside your clutch bell.... so when the truck needs to supply some power it starts slipping.... what could have happened is your clutch got so hot it melted a little bit and now there is a slight film on your clutch bell.... check this out!! and see if that helps.
#43
WA
RE: Tmax 2.5 Won't Shift
Knightlord,
My neighbor had the same problem with his Sportmaxx. With your engine off and transmitter and radio on.... squeeze your throttle trigger and look in the carb to see if your throttle opens all the way. His didn't open fully, so while he was thinking that he was giving his truck full throttle; his carb was only opening half way. If this is your problem; just adjust your throttle linkage to open fully when you squeeze your trigger.
--PQ
--PQ
#44
i got it fixed i had the low end adjst wrong.. i'm still not happy with it after getting the tranny fixed seems abit slow.. but never know it might just be me.. i am thinking about selling it don't have the time anymore and the funds to go out and play around..
#45
WA
You could always lean out the low end needle some more and richen up the HSN so you can maintain a good temp. That would give you some excellent speed. I did it on my Tmaxx.
PQ
PQ
#47
WA
I'd richen up the HSN little by little. But make sure your engine isn't flooding. if so, turn it over and dump it ( truck upside down, glow plug out, 3-5 pulls on pull starter or press EZ start for about 5-10 secs or until fuel has stopped dripping from glow plug hole).
#48
knight lord dont sell the truck just sell the engine then buy a fantom fr.18 of a srio.18 then u wont have anymore probems i know i dont with my fantom .18
#49
i was thinking about getting a new engine but i still don't have the time or money.. i have had the truck for 6 months and still working on the first gallon..
