Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
Maxx 2.5 Header
Old 11-10-2003, 10:33 AM
Jarret
Default Maxx 2.5 Header
Does anybody know the inside diameter of the header on the Maxx 2.5 header?
Going to build a custom rear exhaust.
Old 11-10-2003, 01:09 PM
Dr. Krass
Default RE: Maxx 2.5 Header
Yes, the specs are listed on www.towerhobbies.com
SPECS: Outlet inner diameter: 11mm (0.43" )
Engine side inner diameter: 13mm (0.51" )
Awesome about the custom exhaust. I built one out of copper pipe it is insanely loud and has monster low and mid range torque, but absolutley no top end! I just set my shift point lower and the truck hauls ass.
Old 11-10-2003, 01:37 PM
Jarret
Would aluminum tubing make any difference over copper tubing?
Also, where did you find the specs for the header at Tower?
I can't find them.
Old 11-10-2003, 01:59 PM
Dr. Krass
http://www2.towerhobbies.com/cgi-bin...?&I=LXDDT8&P=7
I just looked for the t-maxx 2.5 header itself, and it lists the specs in the "tech notes" below the picture of it.
Aluminim tubing should work fine for an exhaust system, I just used copper cause I got a huge piece of it for cheap, and since it's used for household hotwater pluming, I went to home depot and found many copper elbow and T splitter pieces that attach right to the copper tubing. So all I had to do was measure and cut the tubing, fit the pieces together and solder my exhaust system together. Also, the copper tubing is even wider than the 11mm header outlet, so it's F&ckin louder than if you were running a straight header. It actually was too loud for day to day bashing, so I made a little insert silencer that fits into the tail pipe and makes it more like the volume of a very loud tuned pipe. Custom exhausts own all.
Old 11-10-2003, 02:02 PM
Jarret
Cool, thanks for the link.
You soldered your exhaust system together?!?!?!
I am just going to cut off the connectors off of the header and solder them on the tubing. Then it will be just like the regular header but customized.
Old 11-10-2003, 02:33 PM
Dr. Krass
Sounds good. Yes I soldered the exhaust system together, my dad had a torch, and some high temperature thick gauge solder that is ment for stuff like copper tubing (not electrical work if that's what you are thinking).
I will try to get a pic of the exhaust installed later
Old 11-11-2003, 12:34 AM
Dr. Krass
and here it is
Old 11-12-2003, 10:39 AM
Jarret
Hmm, looks like you need to clean your truck!!!
Anyways I am going to try to keep the stock pipe on the truck so that I don't lose any power.
How did you make the silencer?
Old 11-12-2003, 11:17 AM
Dr. Krass
ya it does need to be cleaned...
I just took a much smaller diameter piece of plastic tubing, made a little fitting for it, and jammed it in the end of the pipe. So the exhaust tip was much smaller, and it actually had backpressure. Worked pretty well.
Old 11-12-2003, 12:17 PM
Jarret
Ok.
Nice flowmaster exhaust by the way!! LOL!!!
I'm going to make the exhaust system hopefully this weekend and then over thanksgiving break perfect it.
Then after that send it in to a company either get it powdercoated or chrome it.
It is only the header, but I am thinking about making my own exhaust pipe, just for fun and seeing if I can get any good sounds coming out of it, by making different mufflers for it.
If anybody has made a muffler for the car/truck or has any ideas please post and pics would be nice.
