If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 10 of 10
  1. #1
    Join Date
    Nov 2003
    Florence, SC,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    weak springs??
    i wanted harder springs on my tmaxx so i put more spacers on them, at first they worked great, i loved them, but after i ran it once the springs dont pick up the truck near as much, do you think that weakened the springs?
    Tmaxx 2.5:
    -Epic .18-Dynamite turbo airfilter-THS exhaust-MIP cvds-RPM front shock tower and body mount-Hitec HS 645 steering servo-custom roll bar-custom center skid plate-aluminum hex hubs-carbon fiber brake disc-spool in rear diff.
  2. #2
    Join Date
    Jan 2004
    medicine hat , AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    good question,i have the same problem is the back but not the front so now the truck is all slanted and it looks really gay[:'(]
    There are only a few names who TRULY STRIKE FEAR INTO PEOPLE,thats Jason,Freddie,and Zeroc
  3. #3
    Join Date
    Nov 2003
    Florence, SC,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    the fronts fine on mine, the truck will stay level if i lift it up but after i push it down it only comes up like an inch, it didn't do this before i put the spacers in
    Tmaxx 2.5:
  4. #4
    Join Date
    Jan 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    exact same here[:@]
  5. #5
    Join Date
    Jan 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    i know it supposed to have a little bit of slack but not a little over 1/2 of the stupid shock,i olny have an inch of travel
  6. #6
    godlyone's Avatar
    Join Date
    Dec 2002
    Vancouver, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    You can stuff spacers in all ya want. The only thing a spacer can be used for is ride height only. You can compress a spring to any given length, it will still give the same spring rate. The only way to have a stiffer spring is to buy them. Also consider, by adding more spacers to the stock shocks you are raising the truck and the higher your truck the more likely it will tip over when cornering.
    godlyone
  7. #7
    Join Date
    Nov 2003
    Florence, SC,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    no no no, im dont think you are get my concept, the truck came with adjustable spacers, they go between the spring and the top of the shock, it does raise the hieght any, just presses down on the springs
    Tmaxx 2.5:
  8. #8
    Join Date
    Jan 2004
    Indpls, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    I found some stiffer t-maxx springs(blue ) have them on order can't wait till they get here ..... ....I will check the level of my shock oil they should make it ride a bit better .......... kinda sqautted down ... my bro put a roll cage on his and it sits down a half inch more then mine...... he promptly took it back off till the stiffer springs get here
  9. #9
    godlyone's Avatar
    Join Date
    Dec 2002
    Vancouver, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    ORIGINAL: wakbrdr
    Dude! Those are spacers for adjusting ride height only. You can put spacers on your shocks all day, it won't give you stiffer springs, just higher ride height. Imagine taking a spring off your shock and compressing it halfway, the stiffness of the spring will still be the same stiffness as your others when they are uncompressed. Ya dig? Spring rate is spring rate, it is what it is. If you want stiffer spring rate, get stiffer springs.
    godlyone
  10. #10
    Join Date
    Dec 2002
    Houston, TX,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: weak springs??
    godlyone, is very correct.
    If you guys take a few minutes to look over your manuals and read through a few forums online you will get a grasp of what you are talking about.
    The trinity blue springs are great. If you ordered eight put 4 on your truck and 4 on your bro's. Make sure that you go through you shocks and top them off.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
