siro .18 t-maxx engine
hello, my 2.5 engine is shot and im going to buy a new engine. im leaning toward the siro. will it fit in with 0 modirications? also is it more powerfull than the 2.5. last, will it fit with the pullstart designed for the 2.5 because thats what i have. anyone with this engine give me your advice/comments.
thanks
thanks
RE: siro .18 t-maxx engine
the sirio will drop in with 0 mods. It made to be swaped out with the 2.5. It has loads more power and torque. and the pull start or ez-start will hook up. From what I've heard this is a great engine. Hope you like it
NC
There's also the Fantom, Epic, and Wasp and I'm pretty sure all of those cost less and they have the same amount of power. But if you want that Sirio, I say go for it!! Definitely an awesome engine. Never really heard anything bad about this engine.
The Sirio is excellent! Probably the best modification you can do to your truck! You will be very happy with this engine, and you'll be kicking yourself for not getting it sooner. It's alot more powerful and super reliable, but you should also get the sirio pipe and motor saver filter.
I have almost a gallon through mine now. The power is really coming on strong now and I have started to lean it out more. I have had no problems with tuning issues. I didn't have to hard of a time with my 2.5 but this engine is a dream to tune. Even with 15-20 degree temp swings (sunlight to no sunlight) a quick hour turn left on the high side and your'e set. If you have problems tuning your 2.5 this engine will be a blessing.
The Fantom is right inline with the Sirio as far as power goes. The Epic isn't far behind but the Wasp has a hard time keeping up with the 2.5. The one thing the Fantom doesn't have is the reputation Sirio has for making high quality engines. Fantom has had a sketchy past as far as thier engines are concerned. The FR-18 also runs at way to high of temps for me. The FR-18 needs 320 degrees+ to make the hp, the Sirio rocks house at 230 degrees.
Banned
ORIGINAL: jshelton
do you have to tune the siro .18 as much as the 2.5....im thinking about upgrading....and not sure if it will be easier or harder...
Banned
[sm=drowning.gif]Ok I feel like im drowning,will the sirio engine eat up gears?is it the best out there?I want the best engine for my buck.
Hey foxracing, the sirio will eat slipper clutches if you stick to stock. I have had some success using 12 slipper pegs instead of the stock 6 but the best thing is a double disk slipper clutch like the one made by robinson. It won't start until the engine has used about a gallon of gas but both of mine did it. The sirio halds a tune awesome, makes far more power at 230 degrees than the 2.5 does at 270 deg, and also doesn't seem to care at all what brand fuel you use. I would recommend this engine to anyone who likes to play, not tune. Stock diffs, driveshafts, and tranny gears have no prob so far.
www.hobbypeople.net or any online or local shop should know what you need gear wise. And stop YELLING
NC
ORIGINAL: bigjdubb
dont worry it is still a great engine I have read some people swear by the fantom I have the sirio myself and am very happy but the fantom is exellent as well.
NC
Thanks ZAD, at least now I feel better. Anyone else have any input (does it overheat all the time, power kind of sluggish at times, etc.)?
Also, does anyone know how to change your picture under your name or the quote or whatever under your name and above your picture? And the time zone, I'm in Eastern and it's like on Chinese time. Oh and my birthday, that's not right either. lol this is like the 4th time I've edited this thing.
