truck wont sart once it gets hot?
my truck runs good when i run it for the first time that day but then it get up to the 280 degreee range dies and then wont start until it cools down to the 160 range or lower. whats up with that. it doesnt bogg or anything when im going full speed but once it dies its hard to get going again. what can i do?
RE: truck wont sart once it gets hot?
well i guess im just one of the guys that got suckered into buying it and you guys are right the only thing it does is look cool i am about to take it off its not worth the hassle. my truck has gave me **** since i installed it!
My Feedback: (13)
IN
ORIGINAL: MAXXER2.5ER
its cool i took it off after i read a couple peoples input on it. i was thinking of real cars when i bought it but that mistake wont happen again. it hasnt worked right since i got it anyway so oh well no pain no gain i guess. do you have any input on suspension setups i have the the aftershock steering stablitly in the front but because i have the c-vec z800 pipe mounted on the rear i cant put the rear stability on so instead i have the trinity blue and black springs on the back w/ 60 weight oil. it is real quick to bounce back but it also bottoms out really bad still what can i do.
It's Running to hot. When it heat's up the piston expandes and rubs against the cylinder. Run it richer and cut a hole in the front of the front and rear of the body to allow the heat to excape.
Could alse be vapor lock (because of heat). I had the same problem, but then I bought Fireline (stock #1091) fuel line and the problem went away.
Banned
Not necessarily if its too lean..Just if the mixture in general is not right. You have to have the LSN and HSN at a good setting as to where they complement each other almost.
AL
One mistake that many people make when tuning a T Maxx with a stock tank is when the fuel level is above the carb, more fuel is supplied to the engine but as the level falls to where pressure is needed to push the fuel, volume falls off and your engine will run lean if you have it borderline when the supply pressure is greater. Tuning when the fuel level is just above the carb inlet level is a good place to hit a good tune that will work well for a full tank.
