Post your problem here and I will help you fix it.
RE: Post your problem here and I will help you fix it.
Nothing is helping me with this. 2.5 has had roughly maybe 2-1/2 - 3 gallons through it. I dont know what the deal is. Again once i insert the the glowplug with or without fuel in the motor is acts as if its hydro-locked. But once i take the glow-plug out its fine but still want wind my pull start back up. And trust me there is no fuel in the motor because ive tried to unflood it several times per the instructions on the website, and there shouldnt be fuel in it now anyway because i took the hose out of the carb. Maybe that clears it up a little more.. Some one please help me or atleast tell me where i can look to find out more information on this.. thanks
vicious p - try cleaning the motor, make sure everything is working smoothly. If the pull start string doesn't retract back up the spring might have came unhooked or even broken.
I hated my 2.5, I never got the thing tuned and running good for long
