Tmaxx differential oil setup
I am wondering what a good grease weight setup would be to use on my front and rear differential, i mainly do bashing but i like to be able to turn, i am going to use ofna silicone oil.Thanks
OR
RE: Tmaxx differential oil setup
ORIGINAL: nitroman99
Oil is the best (like you mentioned), but keeping it in the diff will be difficult if not impossible.
Almost all auto parts stores carry superlube (I think it is made by permatex or loctite). It comes in small tubes.
MI
Yup the TMAXX doesn't seal the diffs so oil is really not an option unless you want to do alot of cleaning and refilling like weekly.
I use [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFTY0&P=7]this.[/link] it is thick enough that it hasn't leaked out in 3 months of running.
I packed mine full of axle grease. It was nice and stiff for about 1 run. Weather that means it heated up and puked it all out or what i dont know.
Im considering going to a full spool for the rear anyway.
I went to a spool in my maxx. Since I only bash it has worked out well, but you will still have to grease the ring and pinion gears
I have been useing ofnas heavyist wieght oil with good luck and performance the lighter oils leaked out immediatly,the heavy stuff stays for quite awhile
AZ
I have probaly broke 10 or more drive lines with a spool in the rear. If you have good drive lines (like MIP's) and the surface you driving on don't have very much traction you might get away with a spool. But as soon as one wheel gets too much grip like sliding your truck around at full throttle you guaranteed to break drive lines. Pavement is the worst, It even says right on the package for off road use only (I found out the hard way[&o]). If you just have the stock engine on your t-maxx everything should be good with a spool (I have not ran a spool with the stock engine though). A T-maxx with any .21 will be very harsh on your drivelines with a spool. My engine also sheer's off the screws that hold the ring on.
I wouldn't recomend a spool for any one.
