Stock Revo Axel Carriers= Junk, alum???
NY
Where can I get some quality aluminum axel carriers for the revo. I brake these things like its my job All I do is beat the hell out of the thing and that is about the only thing that really brakes often. Where can I get aluminum ones I looked with no susccess.
RE: Stock Revo Axel Carriers= Junk, alum???
I think you might be talking about the steering blocks. Here is the linkhttp[link=http://://www.ghhobby.com/products.php?cat=29]://www.ghhobby.com/products.php?cat=29[/link] I think this may help!!!!!
i think what might be happening is that the e clip that holds the pin in the yolk comes off. then the pin starts to wiggle out, and then the yolk snaps. i had this happen once, when i first got the truck. you may also want to double check the setting of your slipper clutch, it doesnt sound like its taking the stress off the driveline. good luck
NY
Just went to the ghhobby website and looked at their products. That is exactly what I am looking for. Are their poarts of good quality. I would rather waste 8 bucks a time than 50. I would think the aluminum would never break again if I put them on and they are not really at a point where they would stress other parts to much.
rozzibandit,
What exactly is the problem you are having with them? You said you are breaking them, but did not say what is breaking. Are you popping the pillow balls out? Breaking the whole axle carrier?
Here is the link from above [link=http://www.ghhobby.com/ProdDetails.php?id=327]GH REVO Steering blocks[/link]
We will be coming out with ours soon.
Roy
Roy
wow thats one part i havent broke and i thought i was the original revo killer here is my list of broken parts 5 diff sets 2 optidrive gear sets lots of turn buckles and push rods for the shocks 2 sets of long travel rockers 3 spur gears 1 motor mount 1 bell gear and clutch 2 slipper clutches 2 sets of talon tires 5 bodies forward reverse servo throttle servo servo box 2 antennas thats all i can think of for now
NY
Hello Roy, That is correct the pillow balls keep popping out and cracking off lil pieces of plastic along with it. If I can bullet proof that I wont have any more problems Also, i am I going to need aluminum caps that keep the pivot ball in place?? Or can I use the stock plastic caps that are on the stock steering blocks?
This company makes them. go to Revo hop ups and you will find them .[link=http://www.ghhobby.com]http://www.ghhobby.com[/link]
AL
Don't you think the knuckles are made to allow the balls to pop out for a reason? I'd think changing to aluminum knuckles that didn't allow this to happen would simply break ball shanks.
ORIGINAL: rozzibandit
Those that are pictured and our will use the stock plastic pillow ball retainers.
Roy
ORIGINAL: popa71
I don't think there made so they will pop out, aluminum is better, I have never broke a pillow ball, There made of plastic yo keep production cost down
