just a vid and a question on the gear sound
http://www.putfile.com/media.php?n=IMAG0103
http://www.putfile.com/media.php?n=IMAG0100
Hey all, I have replaced my friction cylinders, and the spur . and tighten the nylon washer. and replaced my 16t gears i believe the ae the 66, with the orginals. I tend to forget at times. in the vid you can really hear it whine. It was really smooth before, now it is whinning. on top of it before I was not able to pop any wheelie's , now I am able to as i'll post another vid up as well.
RE: just a vid and a question on the gear sound
I didn't watch the vid but a buddies LST did the same thing, we moved the motor away from the spur gear. You need to place a piece of paper in between the two when putting them together.
I would think the friction tabs have a lot to do with the whiining rather ten the space of the gears Will try again. thanx
