hi, i have problem.
hi, i have problem.
I have Revo Stock.
i want to change my engine.
3 options:
1)Rb Tm323 For revo
2)Sirio 23 For revo
3)Picco 26 madium Block for revo.
I need help.
I Want Engine With Nothnig problem.
I Was'nt be in my revo Problem and damage, Because The Engine.
Pliz Help Me.
Tnx'
Shahar.
3 options:
1)Rb Tm323 For revo
2)Sirio 23 For revo
I need help.
Pliz Help Me.
Tnx'
Shahar.
LA
RE: hi, i have problem.
For the Revo the three best motors I have found are the Sirio .23, the OS .18TM and the OS .18TZ. Take note that the OS.18TZ requires some modifications to make fit. the other two drop right in. the trinity revo pipe works well with all three motors. if you go with the Sirio .23 then the ofna JP-1 pipe works best. also with the Sirio use the turbo button with OS P3 glow plugs. Also take note that any motor that is made for the traxxas elec system will work with traxxas pull ropes. all three motors produce good power, and hold very consistant tunes. good luck
MN
ORIGINAL: DEAD MAN
not to be mean or anything but no one can under stand what your sayin dude
Im with this guy!! What the He11 are you asking?
in the future:
can be problem in the gear and in all the car?
if have problem...
what the problem ?
i think do in the gear
40\16
and i have must power.
and must speed.
what u happend?
need to do this?
tnx,
shahar
if have problem...
what the problem ?
40\16
and must speed.
what u happend?
need to do this?
tnx,
shahar
He is asking if he will have trouble fitting a picco .26 max in his revo, and if it requires any mods. Or is it a direct drop in. Give hime a break he is from Israel, and obviously has trouble with english.
Guys, cut him some slack, he's from Israel, if you don't understand him get off the thread and let the people who do, answer him. It's not clear but it's pretty obvious what he's asking. He wants to know which engine the Revo can handle without destroying the thing from too much power. In the last post he wants to know what problems can happen in the future and and what's a good gearing for the motor, for good power and speed.
