Drove Tmaxx in some fine silt....now troubles
My friend and I went to this place and got into some fine silt...we left cause it was too deep of stuff and went someplace else.
When we got done for the day his steering is very sticky and the shocks do not rebound but are full of oil....how do you clean them up? We sprayed down the whole truck with that Nitro cleaner stuff in a can.
DE
RE: Drove Tmaxx in some fine silt....now troubles
for the steering use some wd-40 and spray the moving parts where sand got on. move it around and keep spraying a little bit at a time until the steering loosins up
WA
for the shocks you might have to take them apart. its happened to me. i just took them all apart as best as i could and washed them in WD 40 then i put new oil in them and it worked out pretty good.
