TMAXX 40 series tires 23 mm hex hubs....wheels wobble
I got some proline bowties and the 40 series rims, along with the 23mm hex hubs. My tires wobble kinda. Is this bad and what can I do to fix it.
FL
RE: TMAXX 40 series tires 23 mm hex hubs....wheels wobble
If you've tightened your rim down properly there shouldn't been any wobble between the rim and carrier. Assuming these are new rims and tires, check to be sure you installed the tires to the rims squarely (roundly?), and that the foam is also seated properly. If you didn't it'll appear that your rims are wobbling when they are not.
When I seat my tires to the rims I roll the tires (installed in the rims) in my hand a few times, applying light pressure. This helps get everything centered before gluing.
