hows the freeway speed revo project?
ON, CANADA
RE: hows the freeway speed revo project?
Ya, its my idea. I'm still collecting parts for it.
I just ordered a new CVEC Big Block pipe for my OS .30 and new bearings all around for my RPM steering blocks to make sure everything rolls nicely.
I'm having trouble finding a clutch bell with enough teeth though. The largest I can find is a 20 tooth.
I'm running a 1/8th scale clutch from a Savage and I can't find any larger clutch bells in either 1/8th or 1/10th scale that are the same pitch as Revo spur gears.
I'll be using a 34tooth spur. Does anyone know where I can fine a clutch bell with more teeth?
Also anyone have any of those Hotbodies 7.7 tires they want to sell? They are the biggest tires I can find and larger tires make more of a difference than higher gearing for top end speed.
ON, CANADA
The Jumbo Kongs look like they wouldn't be real good on road at high speeds.
What I would really like is a set of ProLine RoadRage tires but taller.
If there a tire with that type of tread that is taller than the RoadRage tires?
what about these tires????foams...
http://www.philshobbyshop.com/tek9.a...cific=jocnmrr0
