Over heating 2.5
NE
Over heating 2.5
To day I got my truck out and after half a tank the temp hit 320!
I changed the fuel line the glow plug, tank ,I reset to factory setting and retuned.
help
help
Banned
RE: Over heating 2.5
is the engine vents plugged with dirt/grime. that will cause temps too, check for head gasket leaks/glowplug leaks, also check the carb for airleaks... sounds like your lean for some reason. air leak would be where im looking.
Tim
Tim
FL
Check the o-ring around the gas cap. It can get worn and not seal off the gas tank properly. This is a common problem and one of the easiest to fix.
