Revo 2.5R needs new carb - OS?
TX
I need a new carb. I'm on my second stock one - stripped out the plastic around the idle screw on both of them becaue I just could NOT get it to idle high enough to where it wouldn't die when the brakes were applied.
So.. I'm looking for probably an OS carb. Which ones fit the 2.5R without a problem? I've heard the carb from the 18 TM works great, but its a bit too pricey. Are there any others? Or anybody have one they can sell to me? Thanks! [8D]
AB, CANADA
RE: Revo 2.5R needs new carb - OS?
ORIGINAL: pilotwings119
I need a new carb. I'm on my second stock one - stripped out the plastic around the idle screw on both of them becaue I just could NOT get it to idle high enough to where it wouldn't die when the brakes were applied.[8D]
Have you leaned out your HSN and LSN to proper running conditions after break in. Sounds like you are way rich on your LSN and that is requiring a super high idle to compensate.
TX
ORIGINAL: TM323
your idle screw needs to be turned clockwise to stop the carb from closing when the brakes are applied
I finally just got a new motor (without rotostart, using a starter box-type setup) and it made a world of difference.
jqa3 I just got an O.S. carb for my 2.5. Can you please tell me about where you have your nedles set so I have a starting point to get it running thanks
