How to clean Monster Truck??
OH
I am new to r/c's and have a dirty/dusty Revo 3.3 from normal gravel driveway and back yard running. I would like to clean truck, but am afraid of electrical damage or rusting out parts. What are the proper ways of cleaning these trucks?? All advice is greatly appreciated and thanks in advance.
caragland
caragland
GA
RE: How to clean Monster Truck??
I use compressed air ,bushes and Simple Green diluted 1:10. First I brush off big stuff and blow the dust off with compressed air . Next i spray with diluted Simple Green and let set for 5 min. then I blow it off again. I repeat this several times until it is mostly clean.
I try to not get Simple Green in the radio boxs, CB, or on the slipper clutch. I do not direct the compressed air directly at these areas or at the differencials exits.
Some follow this with a misting of WD -40 but I stoped doing this as I think it makes it harder to clean next time.
Guess I should mention that some say Simple Green will attack aluminum.I have had it dechrome part of my wheels but then the compressed air may have done this a;so.
Some only use Denatured Alcohol to coean but I hate the smell and it cost approx.$12 per gallon. I run and clean my truck most everyday
PE, ARGENTINA
Toothe brushes, WD-40, and compressed air work wonders.....being careful to avoid wd-40 on the brakes and clutch, but a final cleaning of the bake pads with brake cleaner will take care of that. Don't use brake cleaner on the clutch as it can wash the lube out of the CB bearings. Any WD-40 on the clutch will burn off in the first couple of minutes of operation...
IL
Exactly. If u dont have this air compressor yet, i strongley recomend one. You could get one for $30. Also, everydayflyer said that he doesnt like to use the WD-40. I would recomend it. Its just cause that old mans been in the buissness to long . no jk. But i think its attracts the dust to the WD 40 and keeps it off the paint and boxes. Then the air compressor takes it off good. Also, where the servos are, take off the lid and put cotten down on any holes where air cant get it. Just so dirt dont get in. Try this stuff and it should work. Later
IL
Highoctane, ever own a go kart? Spray WD-40 on the clutch and myn went up in flames from the spinning so fast. Crazy stuff. But true that burns fast.
OH
Thanks for all input. I just purchase air compressor the other day for projects aroung the garage. One last question - Do you remove anything off truck while peforming cleaning process??
Thanks- caragland
Thanks- caragland
GA
Some remove the Engine and radio gear but I do not. Some completely disassemble the truck every few months or so to do a deep clean. Just depends on how dirty it gets and how clean you want it. Mine has a $90 receiver and a $25 Fail Safe in the radio box instead of the chaep TQ3 so I try tp keep the radio box dry.
Some helpful hints here Scroll down to Seal the Servo Box from dirt.
http://www.e-maxximumrc.com/html/revo.html
PE, ARGENTINA
ORIGINAL: everydayflyer
GA
Perhaps the most complete maintains how to with photos here:
http://www.traxxas.com/support/index...452&artlang=en
TX
Hmmm thats funny I use a paint spray gun and mineral spirits to clean mine. I just spay it every where and blow it off with high air pressure and it seems to take most of the dirt and grime off.
PE, ARGENTINA
ORIGINAL: kevinmachdata
MT
every 6 months i buy all new fule tubing, fule filters, and i take the truck compleatly aprt and put it back to gether and when i do that, i useually buy a couple $100 inparts wile its apart.
ON, CANADA
Every so often (not very often) I take out all my electronis and stick my car in the dishwasher, then I take everything apart, clean wat wasnt cleaned, relube everything an fix wat needs to be fixed. Saves alot of effort, just dont wash dishes before you do an empty run on the dishwasher.
FL
I got a faster way to clean your truck. Take a garden hose and wet a 5-10 foot strip of lawn.Do a few highspeed passes through the grass and your good to go!
I use something like this http://huskytools.com/husky/Category.../Product8.html, but mine is from harbor freight, and some DNA. Works well.
if you want to be fool proof and not ruin the electronics but dont want to remove them, use electric motor cleaner. spray enough on the bad spots to loosen the grease and dirt then a light spray everywhere else, then just blow it dry with an air compressor. this will guarantee that you dont ruin the electronics. a small bit of grease in the vital areas is recommended though since the cleaner will make it very dry.
