REVO RACIN' THREAD
#326
RE: REVO RACIN' THREAD
hey west you need a center diff i just got rid of mine my car was 10mph slower a little asier to handle but it was like front wheel drive . center diff has a longer shaft that allows rear brake but the rear brake setup has a design fault which does not have enough thread for the mounting screws ...dont bother traxxas have been aware of this and have done nothing about it my brand new platinums rear brake lasted about a week then the screws fell out i have since converted to wide ratio forward only and now the car hammers faster than ever
#327
are you using the stock gearing with the close ratio? ive been thinking about doing the close ratio because the track i race is pretty tight with only one real straightaway.
#328
Let's see
Revo 3.3 chassis
dx3r radio
OS 18TZ(p)
40 mm flywheel
imex pipe
imex air cleaner
center diff
platinum throttle servo mount
platinum radio box
red aluminum push rods
rpm arms
17 mm hex
losi truggy rims
crime fighter lrp's
traxxas wing & mount
tekno throttle conversion
m2c racing chassis plate
slayden steering mod
Futaba 9351 steering servo
Futaba coreless throttle/brake servo
wide ratio gears
36t spur
17t pinion
Revo 3.3 chassis
dx3r radio
OS 18TZ(p)
40 mm flywheel
imex pipe
imex air cleaner
center diff
platinum radio box
rpm arms
17 mm hex
losi truggy rims
crime fighter lrp's
wide ratio gears
36t spur
17t pinion
#329
i now are using wide ratio forward only the close ratio center diff was like a front wheel drive it is probably good on a tight circuit
#331
NC
ORIGINAL: motoxer52
i have a question for all the revo guys, i bought the foward only conversion and put together and im having problems w/ the brake that is, the shaft that came with it is too short it seems as the it does not allow the drive shaft back on the brake is in the way. i took the disc off and the brake pins hit the trans before the hole line up??? did i need to get something else or what?
#333
yeah there bothe the same. Does anyone still race your revos anymore? It seems like everyone has abondoned the racing threads on here. I have a question for you guys that do race. I have a revo 2.5 with a new 3.3 in it and a few other hopups Im debating on making it an all out racer or just starting from scratch with a truggy. Any opinions?
#335
WY
Racing has died down in most places do to people going back to school and being at their kids sporting events. There is only two really big racing events for MT's and thats RC Pro and Diggers Dungeon (not racing just bashing but still a big event).
