Has anyone installed a Center Differential Revo 2.5R??
I've just eat up my 2nd reverse gear with in my Revo 2.5R (it has an OS 18 TM). So i'm thinking of going with the center diff, has anyone installed it in the 2.5R chassis. I was doing some reading and saw where i may need a shorter diff shaft from the center diff in order for it to work on the 2.5R, chassis has anyone done this upgrade??
RE: Has anyone installed a Center Differential Revo 2.5R??
You can shorten your shaft by yourself with a dremel, but i'd imagine it'd be painful. You will also need a 3.3 tranny case for the rear brake(which you will also need)
I'll need a rear brake, does that mean i'll have to remove the exisiting front brake?? Have you actually done the conversion?
What will i need to do with the dremel, cut the shaft or shape it ?
NC
DO they sell the shorter shafts for the conversion or no? If you find out anymore info on this conversion let me know sounds like something I' be interested in.
