aftermarket ring and pinion gear for t-maxx??
T-maxx 2.5
well busted my pinion gear real bad in my t-maxx,, what are my options,,
i dont wanna go with the stock traxxas ring and pinion setup,, cos the same thing might happen,, any aftermarket aluminium stuff i can get ???
thanks
thanks
RE: aftermarket ring and pinion gear for t-maxx??
http://www2.towerhobbies.com/cgi-bin...?&I=LXMYV8&P=7
will this part do,, i only need the pinion, my ring gear is fine,, but its the stock traxxas one ,, do i have to go with all RR parts or can i just fix the that part above only and fix it along with my stock t-maxx ring gear,,????
http://www2.towerhobbies.com/cgi-bin...&I=LXSP75&P=ML
or should i just replace it with a traxxas diff set, ,which is only 10 bucks,, for the entire setup,,
