engine rebuild help
PA
engine rebuild help
as a couple of you may know, i stripped the head screws and need to replace my crank case. im following the instructions on traxxas's site ([link]http://www.traxxas.com/products/nitro/trx33/blueprints/manuals_instr/051219_TRX33_Own_Man.pdf[/link]
page 36 it starts) well, im at the point where i have to take the sleeve out. it says use a plastic or wooden stick to push it out. well, ive broken 2 sticks and it didnt budge. any suggestions? (trx 3.3)
GA
RE: engine rebuild help
Piston at BDC, big zip-tie or popsicle stick thru the ports, turn the engine over.
That will usually push it out enough to get a grip on.
ORIGINAL: DaveG55
If that will not work i have heard of heating the motor up to let the metal expand and push it with the stick after its cool to the touch.
