Slipper Clutch Upgrades
TX
Here's the deal. Stock Emaxx that we put 8.4 batteries in. Here's the problem were burning up the slipper clutch and spur gears. Were can we go the upgrade parts. Any help would be appreciated. . Mike
AB, CANADA
RE: Slipper Clutch Upgrades
Or conversely, you are running the slipper too loose and the slipping is causing friction and heating up the spur gear, melting it. Whatever it is set at now, try going the other way and see what happens.
