Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
Better braking for Tmaxx?
Old 10-15-2007, 04:48 PM
madbrad70
madbrad70's Avatar
Default Better braking for Tmaxx?
My truck just dosent stop very fast. I upgrade the throttle/brake servo, took all the slack out of the wire that pulls on the brake pads too. I then read about glueing 2 brake pads together so they dont flex but that really didnt make much of a differance either. Any other ideas?
Old 10-15-2007, 04:52 PM
chvydrver
Default RE: Better braking for Tmaxx?
Have you checked your trim on the controller?
Old 10-15-2007, 05:37 PM
Mz
Mz's Avatar
does the braking system have a spring or fuel tubing? if it has a spring, cut a piece of fuel tubing the same size as the spring and swap.
you could also get brake cleaner and spray the disk.
Old 10-15-2007, 05:43 PM
jatoracing33
jatoracing33's Avatar
well, if its semi metallic then get a steel one. if its steel then do a brake mod like said right above
Old 10-15-2007, 08:25 PM
nitrorcjunkie
nitrorcjunkie's Avatar
If the brakes are set up properly and the epa and exp on your radio are set correctly, you should be able to pull stoppies at will with the stock brakes.
Old 10-15-2007, 09:11 PM
RCCanuck
the Tmaxx has brakes????[X(]
