Twin 3.3 revo early prototype
PA
RE: Twin 3.3 revo early prototype
if you go on www.traxxas.com and go on surfers rides thers a maxx with twin 2.5r's i duuno if it still on there it was a wile back i saw it. but look on youtube to see if anyone has done it and ask them how they set it up? good luck anyways
the linkage looks ok but im not sure how it would work as i have NEVER seen a revo other than the internet you should consider scraping the stock chassis engine layout can you get the picture for me and i will show you whAT i mean lol and no i dont have a twin maxx but it would be piss easy lol as the gear box is centeral and the chassis is perfectley flat lol (well mine was till the picco.26 met the wall at wot)
ORIGINAL: joelgould111
Ill try to get the picuture up in about 4 hours!
I also WOT'ed into a lighting post during late break in.
breking in my picco was a nightmare i started her up and the engine ripped uff the chassis lol new engine mount
#32
WY
heres somtin i was thinkin about last night to mount two engines on the revo. It could work with some work. Yes I know my writing sucks but its hard to write with a mouse lol
#33
sorry about the treable picutre my good pc has decided not to work today lol but any way the white square thing would be bolted to the chassis using any axalible holeas and making new ones then the engine mounts would be bolted on straight not at dogy angles like i drew lol c u 2 moro im going 2 sleep lol pm me if u need any better drawings lol
#34
in reply to Clymer: ^^^ Also though about it, but how do you get the power over to the spur gear which is located 1/3 of the distance between the two engines, near the left engine?
The t-maxx have a very large spur gear I have seen which this was so easy!
#36
WA
why don't you get that new emaxx tranny, it would be really easy to mount two motors, and it would take alot less engineering. I was thinking that you could mount the engines at a slant, to keep the CG low, and keep them from sticking out of the top. kind of like this: \^/ with the ^ as the tranny and the slashes as the engines of course there was one guy on here that had a maxx with 4 enginse, a savage with two, and some others I think. can't remember his name though. do a search, you might find something.
#37
ORIGINAL: BRUSHLESS BASHER
Is it a pure drop in?
I need to figure out gear ratio.
Question 2, how much can you slant the engines without affecting them somehow?
#38
Revo 3.3 Stock final drive: 23.85/16.54
E-maxx Stock final drive: 28.91/17.95
NewE-maxx Stock final drive: N/A / 18.67
Could work out.
There is no disc-brake thingie!! [:@]
The e-maxx tranny sits in front whereas revo tranny sits in the middle->rear. [X(]
Could work out.
#39
If you need any prototype parts, at school we have this machine were you can design your part and it will make it out of plastic that s a little bit stronger than stock plastic, the only down side is that it will cost about 20 bucks.
#40
ORIGINAL: tmaxxman1212
Cool!
#42
om well here it is after like 5 mins realy tyred work the design plan lol
With current 15+40 config the engine mounts will intersect each other.
#44
WY
Looks good but your gonna have to switch to alum shocks ends other wise they are gonna melt and your not gonna have alot of room for a fuel tank from what i can see in that pic.
#45
ORIGINAL: Clymer122693
Iam currently doing an experiment turning the shocks backwards out to the rear of the chassis to get them out of the way.
#46
mmmm sounds intresting hope the shocks work 4 u lol how big in (mm) do you need the spur gear to be to make them mounts sit side by side
#47
#48
OK, the tranny goes forward 10mm and the suspension points backwards, iam making a prototype of the suspension and gonna do some test how it performs.
If this works out. The enigines can sit side by side with 40T/15T and some twiddling with the engine mounts..
PIcs later today..
PIcs later today..
