what is this ??
MD
RE: what is this ??
its plastic, molds arnt plastic are they?? and no bolt holes line up anywhare that i can find... it matches the skids i got same blue color...
MD
RE: what is this ??
ther isnt a x on it... i dont know what it could be to... maybe if i post it on thr mt forum i may get more results this really bugs me
RE: what is this ??
i think its the wear plate.
80115 Blue Three Piece Skid / Wear Plate Set
Please note - RPM skid / wear plates require the use of stock, plastic skid plates, bulkheads, & (for center skid plates) chassis braces. RPM skid plates will work with most aftermarket aluminum front & rear skid plates but RPM guarantees the fit only when used with stock parts.
very last option u can find that at
http://www.rpmrcproducts.com/product...Pts2.htm#skids
or it looks like to bee something thing from this http://www.rpmrcproducts.com/product...Pts.htm#Braces
7th one down the bulk braces.
MD
RE: what is this ??
it doesnt fit anywhare with the skids, and i think when they say wear plate there talkin bout the 3pc skids cause they just cover the stock skids hince "wear plates"..?? i think it may go to another car but idk what it doesnt have a rpm logo on it and ive never seen a rpm part with no logo...
MD
RE: what is this ??
i e-mailed him but no answer... maybe its a secret part that he stole from rpm that will change rc forever... oh sorry... that was a dream...lol
KY
RE: what is this ??
Ah come on you guys, you really don't know what it is? Its so easy.
Obviously, RPM is part of an underground scandal and its a key. They've gave it to you becasue they believe you're the "chosen one." You'll need to Mapquest the Hover Dam and drive there. Once you get there, take the "tour" which really is a test to see if you have the key. Once you get toward the 34th gray door on your left, say you need to use the restroom. They'll know what you really mean. Inset the key with the raised side up into the door and it will slow creak open. There will be the vapor lock hissing sound and steam just like on the movies. In the middle of the room you'll see a black box. It's a voice activated safe. Say the password, "tour guide" and it will open. Then you will see a bottle, but it has a special cork that will only open with one cork screw. Then take a plane to to Benjamin Franklin's home and take that tour and say you need to open some wine. They'll bring you the cork screw in a golden box. Open the bottle. It will give you an old ladies address in California. When you get there, knock on the door 3 times. She will say, "Hello sonny, would you like some cookies?" You say, "Yes." She will ask you which kind you'd like, you say "Chocolate." Then she will take you into a back room with an old typewriter. She will ask you to wait here. In a few minutes, she'll bring you a piece of paper with numbers on it. You'll need the code to decipher it. Look behind your ear. Then type it into the typewriter and you will find the name of the unknown solider! Good luck!
RI
RE: what is this ??
ORIGINAL: Redrawker
