Traxxas Monster Truck forum Discuss the Traxxas T-Maxx, E-Maxx, Super-Maxx and all other Traxxas monster trucks in this forum. You may also optionally discuss them in our MT general discussion forum.
throttle servo noise
Reply
Old 12-08-2007, 07:06 PM
sunco1
sunco1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default throttle servo noise
i took my revo apart just for some good cleaning, and when i took out the throttle servo, i heard something rattleing inside...
i have been having this problem that when im coming back from high speeds my thottle sticks at a certain point. i still hace control of steering but not throttle. and like 3 seconds later i regain control.
could this noise inside be the cause?
and is it time to get a new servo???
sunco1 is offline
Old 12-08-2007, 07:14 PM
george3.3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: throttle servo noise
it sounds like it is time for a new one. first open up the case and see what is rattling around inside. it could be something getting caught in the gears but you never know until you open it. good luck!
george3.3 is offline
Old 12-08-2007, 07:19 PM
REVO X
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
as montecristo said... open it up and see what causes the rattling, maybe the gears are not meshing right of pieces of the gear are tearing apart... if thats the case you might end up getting a new servo.
REVO X is offline
Old 12-08-2007, 07:23 PM
sunco1
sunco1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok thanks. i will do that now. hos much oz. of torgue does the stock one put out?
sunco1 is offline
Old 12-09-2007, 05:02 PM
george3.3
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i think its around 80oz you can get a stock one on ebay really cheap uless you want to upgrade it. which i would do.
Old 12-10-2007, 05:26 AM
Hairballusmaximus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you have to replace the servo consider the tower hobbies high torque or the hitec 5645 (160 or 180 oz in @6 volts cant remember which) If it is only strpped gears you can get gear sets for 4-6 bucks
Hairballusmaximus is offline
Old 12-10-2007, 05:40 AM
squeeguk
squeeguk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My throttle servo did the same thing, there is an IC or resistor or something that should be soldered to the board on the bottom of the servo, this has broken off and is rattling, not very good quality.
I have now replaced it with a Hitec HS-645MG, which is more than enough to drive the throttle fully open now without any hassles.
Don't try and use a digital servo with the standard receiver, it doesn't work. I tried a digital servo and it just twitched the whole time and through it's travel.
squeeguk is offline
Old 12-10-2007, 05:48 AM
Hairballusmaximus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Didnt know that about the digital stuff, Mine has hi-tec fm 75mhz rec in it. High torque servo also equal awsome brakes.
Old 12-10-2007, 02:52 PM
sunco1
sunco1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so will the 5645mg work with stock reciever?
sunco1 is offline
Old 12-10-2007, 03:40 PM
sunco1
sunco1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so lets say i bought a spektrum dx2... could i then use digital servos?
because i want to get a hitec digital servo for a single steering conversion
sunco1 is offline
Old 12-10-2007, 04:25 PM
squeeguk
squeeguk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
From what I understand, you need something like the Spektrum or an FM (could be wrong here) system to use a digital servo. However I have an Airtronics which is a computer radio which I use on my Revo, but still the stock receiver, but not 2.4Ghz, and was told that so long as you can adjust the EPA, then you should be ok. With the stock Traxxas receiver, the digital servo I used didn't like it, however in the Spekky receiver it works a treat.
Perhaps, give Traxxas support a call and ask them to make double sure.
squeeguk is offline
Reply
Display Modes
