tmaxx noise? plx help
MD
my maxx is making a squeeling noise... i replaced the clutch bearings and bell... still noise.... i replaces clutch shoes cause the spring was rubbing bell... still noise... ?? what could it be?? i tightened up the slipper clutch and didnt help.... thanks
RE: tmaxx noise? plx help
i had this problem as well every time i put my engine back in my maxx it would make a high squelling sound it wentaway after a while but i replaced the exhaust and it went it was the exhatust was caching on the flywheel lol
MD
its not my exhaust, it may be the tranny though... what bearings usually go first? i have the foc btw... so i have a couple extra bearings i could use for temp fix cause im broke...
CA
I don't know about "usually" but I just had the bearing on the inside of the input shaft go bad and wreak a bit of havok. I don;t remember if this was the truck that was squeeling, but the next time one of mine does that, I will try to find the problem before it gets worse. Live and learn.
MD
i would like to put new grease or something in the newer bearings before i put them in, what is my options? a heavywieght oil? bearing grease on 1:1 cars? i have white spray grease also... i dont have any rc grease or oil .... so im kinda stuck....
ON, CANADA
a drop or 2 of good bearing oil....grease will just fling off...
here ya go:
http://www.bocabearings.com/main1.as...d=13939&n=ROAD
here ya go:
