O.S. 21tm Question??
TX
I installed the O.S. 21tm this weekend and broke it in. The engine is a monster, but now i have a problem!! The truck is squealing during accelleration, and I cannot determine if it is the clutch or the slipper?? So my question is what clutch would hold up to the power this engine puts out? Can I put an 1/8 scale flywheel and clutch from a BB or is thier a good small block setup that I can use? Thanks ahead for the answers!!!!!
WA
RE: O.S. 21tm Question??
Check your gear mesh and make sure your spur gear isn't getting pushed into the clutch bell. Re torque down your engine mount/angle bolts.
TX
I appreciate the response!! My gear mesh looks good it has a tiny bit of play. The thing is it did wheelies like mad at first and now it will hardly do them at all?
KY
ORIGINAL: silverj
TX
I was a little over a quarter turn out on the slipper and have not adjusted it. And I am running the stock clutch, with about a half gallon through the 3.3 and around a quart through the 21TM, so relatively new. I thought about the nova clutches, I will try them out and go from there! Thanks!!
FL
Squealing sound and not doing wheelies? That's a slipper prob. Too much slip will heat up the slipper pads or pegs and wear them out prematurely.
